Datasheet LT6015, LT6016, LT6017 (Analog Devices)
Description3.2MHz, 0.8V/μs Low Power, Over-The-Top Precision Op Amps
Pages / Page22 / 1 — FeaTures. DescripTion. Input Common Mode Range: V– to V– + 76V. …
FeaTures. DescripTion. Input Common Mode Range: V– to V– + 76V. Rail-to-Rail Input and Output. Low Power: 315μA/Amplifier
Datasheet LT6015, LT6016, LT6017 Analog Devices
LT6015/LT6016/LT6017 3.2MHz, 0.8V/µs Low Power, Over-The-Top Precision Op Amps
FeaTures DescripTion
n
The LT®6015/LT6016/LT6017 are single/dual/quad rail-to- n
rail input operational amplifiers with input offset voltage n
trimmed to less than 50µV. These amplifiers operate on n
Operating Temperature Range: –55°C to 150°C
single and split supplies with a total voltage of 3V to 50V n
VOS: ±50μV (Maximum)
and draw only 315µA per amplifier. They are reverse n
CMRR, PSRR: 126dB
battery protected, drawing very little current for reverse n Reverse Battery Protection to 50V supplies up to 50V. n Gain Bandwidth Product: 3.2MHz The Over-The-Top® input stage of the LT6015/LT6016/ n Specified on 5V and ±15V Supplies LT6017 is designed to provide added protection in tough n High Voltage Gain: 1000V/mV environments. The input common mode range extends n No Phase Reversal from V– to V+ and beyond: these amplifiers operate with n No Supply Sequencing Problems inputs up to 76V above V– independent of V+. Internal n Single 5-Lead SOT-23 (ThinSOT™) Package resistors protect the inputs against transient faults up n Dual 8-Lead MSOP to 25V below the negative supply. The LT6015/LT6016/ n Quad 22-Lead DFN (6mm × 3mm) LT6017 can drive loads up to 25mA and are unity-gain
applicaTions
stable with capacitive loads as large as 200pF. Optional external compensation can be added to extend the capaci- n High Side or Low Side Current Sensing tive drive capability beyond 200pF. n Battery/Power Supply Monitoring The LT6015 is offered in a 5-lead SOT package. The LT6016 n 4mA to 20mA Transmitters dual op amp is available in an 8-lead MSOP package. The n High Voltage Data Acquisition LT6017 is offered in a 22-pin leadless DFN package. n Battery/Portable Instrumentation L, LT, LTC, LTM, Linear Technology, Over-The-Top and the Linear logo are registered trademarks and ThinSOT is a trademark of Linear Technology Corporation. All other trademarks are the property of their respective owners.
Typical applicaTion Precision High Voltage High Side Load Current Monitor Output Error vs Load Current
0.2 0 V 5V BAT = 1.5V TO 76V 0.1µF –0.2 200Ω + 100Ω 1% 0.1Ω –0.4 LT6015 10W BSP89 200Ω – 1V/A –0.6 0V TO 1V OUT OUTPUT ERROR (%) VBAT = 1.5V LOAD 2k –0.8 VBAT = 5V VBAT = 20V VBAT = 75V 601567 TA01a –1.00.01 0.1 1 LOAD CURRENT (A) 601567 TA01b 601567ff For more information www.linear.com/LT6015 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Typical Applications Package Description Revision History Related Parts
