Datasheet LT6015, LT6016, LT6017 (Analog Devices) - 3
Description3.2MHz, 0.8V/μs Low Power, Over-The-Top Precision Op Amps
Pages / Page22 / 3 — elecTrical characTerisTics The. denotes the specifications which apply …
elecTrical characTerisTics The. denotes the specifications which apply over the specified
elecTrical characTerisTics The denotes the specifications which apply over the specified
LT6015/LT6016/LT6017
denotes the specifications which apply over the specified temperature range, –40°C < TA < 85°C for I-grade parts, –40°C < TA < 125°C for H–grade parts, otherwise specifications are at TA = 25°C, VS = 5V, VCM = VOUT = mid-supply. I-, H-GRADE SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 0 < VCM < V+ – 1.75V MS8 Package –50 ±25 50 µV 0 < VCM < V+ – 1.75V SOT-23, DJC22 Packages –80 ±45 80 µV VCM = 5V –125 ±50 125 µV VCM =76V –135 ±50 135 µV 0 < VCM < V+ – 1.75V l –250 ±45 250 µV VCM = 5V to VCM = 76V l –350 ±50 350 µV ∆VOS Input Offset Voltage Drift 0.75 µV/°C ∆TEMP ∆VOS Long Term Voltage Offset Stability 0.75 µV/Mo ∆TIME IB Input Bias Current 0.25V < VCM < V+ – 1.75V –5 ±2 5 nA VCM = 0V –60 –16.5 0 nA VCM = 5V to 76V 11 14 17.5 µA 0.25V < VCM < V+ – 1.75V l –15 ±2 15 nA VCM = 0V l –150 –16.5 0 nA VCM = 5V to 76V l 7 14 23 µA VS = 0V, VCM = 0V to 76V l 0.001 1 µA IOS Input Offset Current 0.25V < VCM < V+ – 1.75V –5 ±2 5 nA VCM = 0V –5 ±2 5 nA VCM = 5V to 76V (Note 6) –500 ±50 500 nA 0.25V < VCM < V+ – 1.75V l –15 ±2 15 nA VCM = 0V l –15 ±2 15 nA VCM = 5V to 76V (Note 6) l –500 ±50 500 nA VCMR Common Mode Input Range l 0 76 V CIN Differential Input Capacitance 5 pF RIN Differential Input Resistance 0 < VCM < V+ – 1.75V 1 MΩ VCM > V+ 3.7 kΩ RINCM Common Mode Input Resistance 0 < VCM < V+ – 1.75V >1 GΩ VCM > V+ >100 MΩ en Input Referred Noise Voltage Density f = 1kHz VCM < V+ – 1.75V 18 nV/√Hz VCM > V+ 25 nV/√Hz Input Referred Noise Voltage f = 0.1Hz to 10Hz 0.5 µVP-P VCM < V+ – 1.75V in Input Referred Noise Current Density f = 1kHz VCM < V+ – 1.75V 0.1 pA/√Hz VCM > V+ 11.5 pA/√Hz AVOL Open Loop Gain RL = 10kΩ l 300 3000 V/mV ∆VOUT = 3V PSRR Supply Rejection Ratio VS = ±1.65V to ±15V l 110 126 dB VCM = VOUT = Mid-Supply CMRR Input Common Mode Rejection Ratio VCM = 0V to 3.25V l 100 126 dB VCM = 5V to 76V l 126 140 dB VOL Output Voltage Swing Low VS = 5V, No Load l 3 55 mV VS = 5V, ISINK = 5mA l 280 500 mV VOH Output Voltage Swing High VS = 5V, No Load l 450 700 mV VS = 5V, ISOURCE = 5mA l 1000 1250 mV ISC Short-Circuit Current VS = 5V, 50Ω to V+ l 10 25 mA VS = 5V, 50Ω to V– l 10 25 mA 601567ff For more information www.linear.com/LT6015 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Typical Applications Package Description Revision History Related Parts
