Datasheet LT6015, LT6016, LT6017 (Analog Devices) - 4
Description3.2MHz, 0.8V/μs Low Power, Over-The-Top Precision Op Amps
Pages / Page22 / 4 — e lecTrical characTerisTics The. denotes the specifications which apply …
e lecTrical characTerisTics The. denotes the specifications which apply over the specified
e lecTrical characTerisTics The denotes the specifications which apply over the specified
LT6015/LT6016/LT6017
denotes the specifications which apply over the specified temperature range, –40°C < TA < 85°C for I-grade parts, –40°C < TA < 125°C for H–grade parts, otherwise specifications are at TA = 25°C, VS = 5V, VCM = VOUT = mid-supply. I-, H-GRADE SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
GBW Gain Bandwidth Product fTEST = 100kHz 2.85 3.2 MHz l 2.5 3.2 MHz SR Slew Rate ∆VOUT = 3V 0.55 0.75 V/µs l 0.45 0.75 V/µs tS Settling Time Due to Input Step 0.1% Settling 3.5 µs ∆VOUT = ±2V VS Supply Voltage 3 50 V l 3.3 50 V Reverse Supply (Note 7) IS < –25µA/Amplifier l –65 –50 V IS Supply Current Per Amplifier SOT-23 Package 315 345 µA MS8, DJC22 Packages 315 335 µA l 315 500 µA RO Output Impedance ∆IO = ±5mA 0.15 Ω
The
denotes the specifications which apply over the specified temperature range, –40°C < TA < 85°C for I-grade parts, –40°C < TA < 125°C for H–grade parts, otherwise specifications are at TA = 25°C, VS = ±15V, VCM = VOUT = mid-supply. I-, H-GRADE SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOSI Input Offset Voltage –80 ±55 80 µV l –250 ±55 250 µV VS = ±25V –110 ±75 110 µV VS = ±25V l –250 ±75 250 µV ∆VOSI Input Offset Voltage Drift 0.75 µV/°C ∆TEMP IB Input Bias Current –5 ±2 5 nA l –15 ±2 15 nA IOS Input Offset Current –5 ±2 5 nA l –15 ±2 15 nA VCMR Common Mode Input Range l –15 61 V CIN Differential Input Capacitance 5 pF RIN Differential Input Resistance 0 < VCM < V+ – 1.75V 1 MΩ VCM > V+ 3.7 kΩ RINCM Common Mode Input Resistance 0 < VCM < V+ – 1.75V >1 GΩ VCM > V+ >100 MΩ en Input Referred Noise Voltage Density f = 1kHz VCM < V+ – 1.75V 18 nV/√Hz VCM > V+ 25 nV/√Hz Input Referred Noise Voltage f = 0.1Hz to 10Hz 0.5 µVP-P VCM < V+ – 1.25V in Input Referred Noise Current Density f = 1kHz VCM < V+ – 1.75V 0.1 pA/√Hz VCM > V+ 11.5 pA/√Hz AVOL Open Loop Gain RL = 10kΩ l 200 1000 V/mV ∆VOUT = 27V PSRR Supply Rejection Ratio VS = ±2.5V to ±25V l 114 126 dB VCM = VOUT = 0V CMRR Input Common Mode Rejection Ratio VCM = –15V to 13.25V l 110 126 dB VOL Output Voltage Swing Low VS = ±15V, No Load l 3 55 mV VS = ±15V, ISINK = 5mA l 280 500 mV VOH Output Voltage Swing High VS = ±15V, No Load l 450 700 mV VS = ±15V, ISOURCE = 5mA l 1000 1250 mV 601567ff 4 For more information www.linear.com/LT6015 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Typical Applications Package Description Revision History Related Parts
