Datasheet LT6015, LT6016, LT6017 (Analog Devices) - 9
Description | 3.2MHz, 0.8V/μs Low Power, Over-The-Top Precision Op Amps |
Pages / Page | 22 / 9 — Typical perForMance characTerisTics. Voltage Offset Shift vs Thermal. … |
File Format / Size | PDF / 1.0 Mb |
Typical perForMance characTerisTics. Voltage Offset Shift vs Thermal. Warm-Up Drift. Over-The-Top Warm-Up Drift. Cycling
LT6015/LT6016/LT6017
Typical perForMance characTerisTics Voltage Offset Shift vs Thermal Warm-Up Drift Over-The-Top Warm-Up Drift Cycling
2.5 2.5 18 VS = ±15V 5 UNITS, 10 CHANNELS VS = 5V 5 UNITS, 10 CHANNELS FOUR THERMAL CYCLES –55°C TO 130°C 2.0 VCM = 0V MS8 PACKAGE 2.0 VCM = 50V MS8 PACKAGE 16 TA = 25°C 1.5 20 DEVICES 1.5 14 40 CHANNELS 1.0 1.0 MS8 PACKAGE 12 VS = 5V 0.5 0.5 V 10 CM = MID-SUPPLY 0.0 0.0 8 –0.5 –0.5 –1.0 6 –1.0 NUMBER OF CHANNELS –1.5 –1.5 4 CHANGE IN OFFSET VOLTAGE (µV) CHANGE IN OFFSET VOLTAGE (µV) –2.0 CHANNEL A –2.0 CHANNEL A 2 CHANNEL B CHANNEL B –2.5 –2.5 0 0 1 2 3 4 5 0 1 2 3 4 5 –25 –20 –15 –10 –5 0 5 10 15 20 25 TIME AFTER POWER ON (MIN) TIME AFTER POWER ON (MIN) VOLTAGE OFFSET SHIFT (µV) 601567 G10 601567 G11 601567 G12
Voltage Offset Shift Over-The-Top Voltage Offset vs Temperature Cycling Voltage Offset vs Temperature vs Temperature
100 150 150 FOUR CYCLES –55°C TO 130°C VS = 5V 5 UNITS, 10 CHANNELS VS = 5V 5 UNITS, 10 CHANNELS 75 VS = 5V, VCM = MID-SUPPLY VCM = MID-SUPPLY MS8 PACKAGE VCM = 50V MS8 PACKAGE 40 CHANNELS MEASURED 100 100 50 MS8 PACKAGE MAXIMUM SHIFT CHANNEL A CHANNEL A MEASURED CHANNEL B CHANNEL B 50 50 25 TYPICAL 0 CHANNEL 0 0 –25 –50 –50 –50 VOLTAGE OFFSET (µV) VOLTAGE OFFSET (µV) VOLTAGE OFFSET SHIFT (µV) MINIMUM SHIFT MEASURED –100 –100 –75 WORST-CASE CHANNEL –100 –150 –150 –75 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 601567 G13 601567 G14 601567 G15
Voltage Offset vs Input Common Mode Voltage Voltage Offset vs Supply Voltage Minimum Supply Voltage
50 100 20 VS = 5V 40 75 15 TA = –45°C 30 50 10 20 TA = 125°C 10 T 25 5 A = 25°C TA = 25°C 0 0 0 T T A = 25°C A = –45°C –10 TA = –45°C –25 –5 –20 T OFFSET VOLTAGE (µV) –50 TA = 125°C –10 INPUT VOLTAGE OFFSET (µV) A = 125°C –30 –40 –75 –15 –50 –100 CHANGE IN INPUT OFFSET VOLTAGE OFFSET (µV) –20 0.01 0.1 1 10 100 5 10 15 20 25 30 35 40 45 50 0 1 2 3 4 5 VCM (V) TOTAL SUPPLY VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) 601567 G16 601567 G17 601567 G18 601567ff For more information www.linear.com/LT6015 9 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Typical Applications Package Description Revision History Related Parts
