Datasheet LT1366, LT1367, LT1368, LT1369 (Analog Devices) - 5
DescriptionDual and Quad Precision Rail-to-Rail Input and Output Op Amps
Pages / Page20 / 5 — TA = 25°C; VS = 3V, 0V; VCM = 1.5V; VO = 1.5V, unless otherwise noted. …
File Format / SizePDF / 396 Kb
TA = 25°C; VS = 3V, 0V; VCM = 1.5V; VO = 1.5V, unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNITS. The
TA = 25°C; VS = 3V, 0V; VCM = 1.5V; VO = 1.5V, unless otherwise noted SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS The
LT1366/LT1367 LT1368/LT1369 e lecTrical characTerisTics
TA = 25°C; VS = 3V, 0V; VCM = 1.5V; VO = 1.5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
∆IOS Input Offset Current Shift VCM = VEE to VCC 1 12 nA Input Bias Current Match (Channel to Channel) VCM = VCC (Note 4) 0 1 12 nA VCM = VEE (Note 4) 0 1 12 nA AVOL Large-Signal Voltage Gain VO = 50mV to 2.8V, RL = 10k 250 1500 V/mV CMRR Common Mode Rejection Ratio (LT1366/LT1368) VCM = VEE to VCC 77 86 dB CMRR Match (Channel to Channel) VCM = VEE to VCC (Note 4) 71 86 dB Common Mode Rejection Ratio (LT1367/LT1369) VCM = VEE to VCC 73 86 dB CMRR Match (Channel to Channel) VCM = VEE to VCC (Note 4) 67 86 dB VOL Output Voltage Swing Low No Load 6 12 mV ISINK = 0.5mA 40 70 mV ISINK = 2.5mA 110 200 mV VOH Output Voltage Swing High No Load VCC – 0.012 VCC – 0.004 V ISINK = 0.5mA VCC – 0.100 VCC – 0.050 V ISINK = 2.5mA VCC – 0.250 VCC – 0.150 V ISC Short-Circuit Current (Note 2) ±10 ±20 mA IS Supply Current per Amplifier 330 500 µA
The
denotes the specifications which apply over the specified temperature range of 0°C < TA < 70°C. VS = 3V, 0V; VCM = 1.5V, VO = 1.5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (LT1366/LT1368) VCM = VCC l 200 575 µV VCM = VEE l 200 575 µV Input Offset Voltage (LT1367/LT1369) VCM = VCC l 200 950 µV VCM = VEE l 200 900 µV ∆VOS Input Offset Voltage Shift (LT1366/LT1368) VCM = VEE to VCC l 200 425 µV Input Offset Voltage Match (Channel to Channel) VCM = VEE, VCC (Notes 4, 5) l 250 900 µV Input Offset Voltage Shift (LT1367/LT1369) VCM = VEE to VCC l 200 675 µV Input Offset Voltage Match (Channel to Channel) VCM = VEE, VCC (Notes 4, 5) l 250 1900 µV VOS TC Input Offset Voltage Drift (Note 3) l 2 6 µV/°C IB Input Bias Current VCM = VCC l 0 15 45 nA VCM = VEE l –45 –10 0 nA ∆IB Input Bias Current Shift VCM = VEE to VCC l 25 90 nA IOS Input Offset Current VCM = VCC l 2 15 nA VCM = VEE l 1 15 nA ∆IOS Input Offset Current Shift VCM = VEE to VCC l 2 15 nA Input Bias Current Match (Channel to Channel) VCM = VCC (Note 4) l 0 2 15 nA VCM = VEE (Note 4) l 0 1 15 nA AVOL Large-Signal Voltage Gain VO = 50mV to 2.8V, RL = 10k l 150 1500 V/mV CMRR Common Mode Rejection Ratio (LT1366/LT1368) VCM = VEE to VCC l 76 83 dB CMRR Match (Channel to Channel) VCM = VEE to VCC (Note 4) l 70 83 dB Common Mode Rejection Ratio (LT1367/LT1369) VCM = VEE to VCC l 72 83 dB CMRR Match (Channel to Channel) VCM = VEE to VCC (Note 4) l 66 83 dB VOL Output Voltage Swing Low No Load l 9 14 mV ISINK = 0.5mA l 45 80 mV ISINK = 2.5mA l 120 230 mV VOH Output Voltage Swing High No Load l VCC – 0.014 VCC – 0.005 V ISOURCE = 0.5mA l VCC – 0.110 VCC – 0.055 V ISOURCE = 2.5mA l VCC – 0.300 VCC – 0.180 V ISC Short-Circuit Current (Note 2) l ±10 mA IS Supply Current per Amplifier l 375 520 µA 1366fb Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Available Options Order Information Electrical Characteristics Typical Performance Characteristics Applications information Typical Applications Package Description Revision History Typical Application Related Parts
