Datasheet LT1355, LT1356 (Analog Devices) - 7
Description | Dual and Quad 12MHz, 400V/µs Op Amps |
Pages / Page | 16 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Short-Circuit Current. … |
File Format / Size | PDF / 692 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Output Short-Circuit Current. Settling Time vs Output Step. vs Temperature. (Noninverting)
LT1355/LT1356
TYPICAL PERFORMANCE CHARACTERISTICS Output Short-Circuit Current Settling Time vs Output Step Settling Time vs Output Step vs Temperature (Noninverting) (Inverting)
65 10 10 VS = ±5V VS = ±15V VS = ±15V 60 8 AV = 1 8 AV = –1 55 6 6 4 10mV 4 50 10mV 1mV 2 2 1mV 45 SINK 0 0 40 SOURCE –2 –2 35 1mV OUTPUT SWING (V) –4 OUTPUT SWING (V) –4 30 10mV 1mV –6 –6 10mV 25 OUTPUT SHORT-CIRCUIT CURRENT (mA) –8 –8 20 –10 –10 –50 –25 0 25 50 75 100 125 50 100 150 200 250 300 350 50 100 150 200 250 300 350 TEMPERATURE (°C) SETTLING TIME (ns) SETTLING TIME (ns) 1355/1356 G10 1355/1356 G11 1355/1356 G12
Frequency Response Gain Bandwidth and Phase Output Impedance vs Frequency vs Capacitive Load Margin vs Supply Voltage
1k 10 18 50 VS = ±15V VS = ±15V TA = 25°C T 17 48 A = 25°C 8 TA = 25°C A A PHASE MARGIN 100 V = 100 6 V = –1 C = 1000pF 16 46 PHASE MARGIN (DEG) 4 15 44 C = 500pF 10 2 14 42 C = 100pF A 13 40 V = 10 0 C = 50pF 1 –2 12 38 AV = 1 –4 C = 0 11 36 GAIN BANDWIDTH OUTPUT IMPEDANCE (Ω) GAIN BANDWIDTH (MHz) 0.1 VOLTAGE MAGNITUDE (dB) –6 10 34 –8 9 32 0.01 –10 8 30 10k 100k 1M 10M 100M 100k 1M 10M 100M 0 5 10 15 20 FREQUENCY (Hz) FREQUENCY (Hz) SUPPLY VOLTAGE (±V) 1355/1356 G13 1355/1356 G19 1355/1356 G15
Gain Bandwidth and Phase Frequency Response Frequency Response Margin vs Temperature vs Supply Voltage (A V = 1) vs Supply Voltage (A V = –1)
18 52 5 5 PHASE MARGIN TA = 25°C TA = 25°C 17 50 VS = ±15V 4 AV = 1 4 AV = –1 R R 16 48 3 L = 2k 3 F = RG = 2k PHASE MARGIN PHASE MARGIN (DEG) 15 V 46 S = ±5V 2 2 14 44 1 ±15V 1 13 42 GAIN BANDWIDTH 0 0 12 VS = ±15V 40 GAIN (dB) –1 GAIN (dB) –1 11 ±5V 38 –2 –2 ±5V GAIN BANDWIDTH (MHz) 10 GAIN BANDWIDTH 36 –3 –3 V ±2.5V 9 S = ±5V 34 –4 –4 ±15V ±2.5V 8 32 –5 –5 –50 –25 0 25 50 75 100 125 100k 1M 10M 100M 100k 1M 10M 100M TEMPERATURE (°C) FREQUENCY (Hz) FREQUENCY (Hz) 1355/1356 G16 1355/1356 G17 1355/1356 G18 13556fc 7 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Applications Related Parts
