Datasheet LT1355, LT1356 (Analog Devices) - 8
DescriptionDual and Quad 12MHz, 400V/µs Op Amps
Pages / Page16 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Power Supply Rejection Ratio. Common …
File Format / SizePDF / 692 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Power Supply Rejection Ratio. Common Mode Rejection Ratio. Gain and Phase vs Frequency
TYPICAL PERFORMANCE CHARACTERISTICS Power Supply Rejection Ratio Common Mode Rejection Ratio Gain and Phase vs Frequency
LT1355/LT1356
TYPICAL PERFORMANCE CHARACTERISTICS Power Supply Rejection Ratio Common Mode Rejection Ratio Gain and Phase vs Frequency vs Frequency vs Frequency
70 120 100 120 VS = ±15V VS = ±15V 60 PHASE 100 TA = 25°C TA = 25°C 80 100 +PSRR 50 PHASE (DEG) VS = ±15V 80 VS = ±15V –PSRR 80 40 60 60 GAIN 30 V 40 S = ±5V 60 GAIN (dB) 20 40 V 20 S = ±5V 40 10 0 T 20 A = 25°C 20 0 AV = –1 R POWER SUPPLY REJECTION RATIO (dB) COMMON MODE REJECTION RATIO (dB) F = RG = 2k –10 0 0 10k 100k 1M 10M 100M 100 1k 10k 100k 1M 10M 100M 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1355/1356 G14 1355/1356 G20 1355/1356 G21
Slew Rate vs Supply Voltage Slew Rate vs Temperature Slew Rate vs Input Level
600 350 500 TA = 25°C TA = 25°C AV = –1 VS = ±15V 500 RF = RG = 2k 300 400 AV = –1 SR+ + SR– SR = R ————— VS = ±15V F = RG = 2k 400 2 250 SR+ + SR– SR = ————— AV = –2 300 2 SR+ + SR– 300 200 SR = ————— 2 200 SLEW RATE (V/µs) 200 SLEW RATE (V/µs) 150 SLEW RATE (V/µs) V 100 100 S = ±5V 100 0 50 0 0 5 10 15 –50 –25 0 25 50 75 100 125 0 2 4 6 8 10 12 14 16 18 20 SUPPLY VOLTAGE (±V) TEMPERATURE (°C) INPUT LEVEL (VP-P) 1355/1356 G22 1355/1356 G23 1355/1356 G24
Total Harmonic Distortion Undistorted Output Swing Undistorted Output Swing vs Frequency vs Frequency (±15V) vs Frequency (±5V)
0.1 30 10 TA = 25°C VO = 3VRMS AV = –1 RL = 2k 25 ) 8 AV = –1 P-P P-P 0.01 20 AV = 1 A 6 V = 1 15 AV = –1 4 0.001 10 VS = ±15V VS = ±5V RL = 5k RL = 5k A OUTPUT VOLTAGE (V A OUTPUT VOLTAGE (V A V = 1 V = 1, 2 V = 1, 5 1% MAX DISTORTION 2% MAX DISTORTION TOTAL HARMONIC DISTORTION (%) AV = –1, AV = –1, 4% MAX DISTORTION 3% MAX DISTORTION 0.0001 0 0 10 100 1k 10k 100k 100k 1M 10M 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1355/1356 G25 1355/1356 G26 1355/1356 G27 13556fc 8 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Applications Related Parts
