Datasheet LT1006 (Analog Devices) - 7
DescriptionPrecision, Single Supply Op Amp
Pages / Page16 / 7 — TYPICAL PERFOR A CE CHARACTERISTICS. 10Hz Voltage Noise Distribution. …
File Format / SizePDF / 304 Kb
TYPICAL PERFOR A CE CHARACTERISTICS. 10Hz Voltage Noise Distribution. Noise Spectrum. 0.1Hz to 10Hz Noise
TYPICAL PERFOR A CE CHARACTERISTICS 10Hz Voltage Noise Distribution Noise Spectrum 0.1Hz to 10Hz Noise
LT1006
W U TYPICAL PERFOR A CE CHARACTERISTICS 10Hz Voltage Noise Distribution Noise Spectrum 0.1Hz to 10Hz Noise
100 1000 V T S = ±2.5V A = 25°C VS = ±2V TO ±15V T V A = 25°C S = ± 2V TO ±18V TA = 25°C Hz) Hz) 80 200 UNITS TESTED √ √ FROM THREE RUNS 300 60 100 CURRENT NOISE 40 NUMBER OF UNITS VOLTAGE NOISE 30 20 NOISE VOLTAGE (100nV/DIV) VOLTAGE NOISE DENSITY (nV/ CURRENT NOISE DENSITY (fA/ 1/f CORNER 2Hz 0 10 16 20 24 28 32 1 10 100 1k 0 2 4 6 8 10 VOLTAGE NOISE DENSITY (nV/√Hz) FREQUENCY (Hz) TIME (SEC) LT1006 • G13 LT1006 • G11 LT1006 • G12
Supply Current vs Temperature Reducing Power Dissipation Increasing Slew Rate (RSET to V–)
500 1000 1 10 10 V V S = 5V, 0V S = ±15V OR VS = 5V, 0V 450 SR SUPPLY CURRENT (mA) A) A) µ µ SLEW RATE (V/ s) I µ ISY 400 SY* VS = ±15V 100 0.1 1 1 SR 350 VS = 5V, 0V µs) SLEW RATE (V/ SUPPLY CURRENT ( SUPPLY CURRENT ( 300 PIN 8 IS APPROXIMATELY PIN 8 IS APPROXIMATELY 60mV ABOVE THE NEGATIVE SUPPLY 60mV ABOVE THE NEGATIVE SUPPLY 250 10 0.01 0.1 0.1 –50 –25 0 25 50 75 100 125 50 10 5 1 0.5 100 1k 10k TEMPERATURE (°C) CURRENT INJECTED INTO PIN 8 (µA) RSET, PIN 8 TO PIN 4 (Ω) LT1006 • G14 *ISY DOES NOT INCLUDE CURRENT THROUGH RSET LT1006 • G16 LT1006 • G15
Output Saturation vs Sink Current Maximum Output Swing Common Mode Rejection Ratio vs Temperature vs Load Resistor vs Frequency
10 5 120 V + = 5V TO 30V VS = 5V, 0V TA = 25°C V– = 0V TA = 125°C 100 4 ISINK = 10mA T 1.0 A = 25°C 80 VS = 5V, 0V VS = ±15V I 3 T SINK = 5mA A = – 55°C 60 ISINK = 1mA 2 0.1 40 I SATURATION VOLTAGE (V) SINK = 100µA I 1 SINK = 10µA MAXIMUM OUTPUT VOLTAGE (V) 20 ISINK = 0 COMMON MODE REJECTION RATIO (dB) 0.01 0 0 –50 –25 0 25 50 75 100 125 0.01 0.1 1 10 10 100 1k 10k 100k 1M LOAD RESISTOR (kΩ) FREQUENCY (Hz) TEMPERATURE (°C) LT1006 • G17 LT1006 • G18 LT1006 • G19 1006fa 7
