Datasheet LT1013, LT1014 (Analog Devices) - 7
DescriptionDual/Quad Precision Op Amps
Pages / Page26 / 7 — Typical perForMance characTerisTics. Offset Voltage Drift with. …
File Format / SizePDF / 573 Kb
Typical perForMance characTerisTics. Offset Voltage Drift with. Temperature of Representative. Offset Voltage vs Balanced
Typical perForMance characTerisTics Offset Voltage Drift with Temperature of Representative Offset Voltage vs Balanced
LT1013/LT1014
Typical perForMance characTerisTics Offset Voltage Drift with Temperature of Representative Offset Voltage vs Balanced Units Source Resistance Warm-Up Drift
10 5 V 200 S = ±15V VS = ±15V VS = 5V, 0V, –55°C TO 125°C V) TA = 25°C 4 100 VS = ±15V, 0V, –55°C TO 125°C 1 TAGE (µ TAGE (mV) 3 0 LT1013 METAL CAN (H) PACKAGE VS = 5V, 0V, 25°C 2 0.1 –100 LT1014 RS INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOL V + 1 S = ±15V, 0V, 25°C CHANGE IN OFFSET VOL LT1013 CERDIP (J) PACKAGE R –200 S – 0.01 0 –50 –25 0 25 50 75 100 125 1k 3k 10k 30k 100k 300k 1M 3M 10M 0 1 2 3 4 5 TEMPERATURE (°C) BALANCED SOURCE RESISTANCE (Ω) TIME AFTER POWER ON (MINUTES) 1013/14 TPC01 1013/14 TPC02 1013/14 TPC03
Common Mode Rejection Ratio Power Supply Rejection Ratio vs Frequency vs Frequency 0.1Hz to 10Hz Noise
120 120 T T A = 25°C A = 25°C VS = ±2V TO ±18V 100 100 TIO (dB) TIO (dB) 80 NEGATIVE POSITIVE V 80 S = 5V, 0V VS = ±15V SUPPLY SUPPLY 60 60 TAGE (200nV/DIV) Y REJECTION RA 40 40 VS = ±15V + 1VP-P SINE WAVE NOISE VOL 20 20 TA = 25°C COMMON MODE REJECTION RA POWER SUPPL 0 0 10 100 1k 10k 100k 1M 0.1 1 10 100 1k 10k 100k 1M 0 2 4 6 8 10 FREQUENCY (Hz) FREQUENCY (Hz) TIME (SECONDS) 1013/14 TPC04 1013/14 TPC05 1013/14 TPC06
10Hz Voltage Noise Noise Spectrum Distribution Supply Current vs Temperature
1000 200 460 TA = 25°C VS = ±15V ) V 180 S = ±2V TO ±18V TA = 25°C Hz Hz /√ 160 328 UNITS TESTED 420 300 FROM THREE RUNS 140 Y (nV Y (fA/√ 120 380 V 100 S = ±15V 100 CURRENT NOISE 80 340 NUMBER OF UNITS VS = 5V, 0V 60 TAGE NOISE DENSIT 30 VOLTAGE NOISE 40 300 VOL CURRENT NOISE DENSIT 1/f CORNER 2Hz 20 SUPPLY CURRENT PER AMPLIFIER (µA) 10 0 260 1 10 100 1k 10 20 30 40 50 60 –50 –25 0 25 50 75 100 125 FREQUENCY (Hz) VOLTAGE NOISE DENSITY (nV/√Hz) TEMPERATURE (°C) 1013/14 TPC07 1013/14 TPC08 1013/14 TPC09 10134fe For more information www.linear.com/LT1013 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications schematic diagram Package Description Revision History Typical Application Related Parts
