Datasheet LT1013, LT1014 (Analog Devices) - 8
Description | Dual/Quad Precision Op Amps |
Pages / Page | 26 / 8 — Typical perForMance characTerisTics. Input Bias Current. Input Offset … |
File Format / Size | PDF / 573 Kb |
Typical perForMance characTerisTics. Input Bias Current. Input Offset Current. vs Common Mode Voltage. vs Temperature
LT1013/LT1014
Typical perForMance characTerisTics Input Bias Current Input Offset Current Input Bias Current vs Common Mode Voltage vs Temperature vs Temperature
COMMON MODE INPUT VOLTAGE, V 5 15 1.0 –30 T V V , 0V (V) A = 25°C CM = 0V CM = 0V 4 10 –25 = +5V 0.8 S 3 5 –20 TAGE, V 0.6 VS = 5V, 0V V 2 V S = ±2.5V S = ±15V V 0 S = 5V, 0V –15 0.4 V 1 –5 –10 S = ±15V VS = 5V, 0V S = ±15V (V) VS = ±2.5V INPUT BIAS CURRENT (nA) 0.2 0 –10 INPUT OFFSET CURRENT (nA) –5 VS = ±15V COMMON MODE INPUT VOL –1 –15 0 0 0 –5 –10 –15 –20 –25 –30 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 INPUT BIAS CURRENT (nA) TEMPERATURE (°C) TEMPERATURE (°C) 1013/14 TPC10 1013/14 TPC11 1013/14 TPC12
Output Saturation vs Sink Small-Signal Transient Large-Signal Transient Current vs Temperature Response, VS = ±15V Response, VS = ±15V
10 V+ = 5V TO 30V V– = 0V ISINK = 10mA 1 ISINK = 5mA 5V/DIV 20mV/DIV ISINK = 1mA 0.1 I SATURATION VOLTAGE (V) SINK = 100µA ISINK = 10µA AV = +1 2µs/DIV 1013/14 TPC14 AV = +1 50µs/DIV 1013/14 TPC15 ISINK = 0 0.01–50 –25 0 25 50 75 100 125 TEMPERATURE (°C) 1013/14 TPC13
Small-Signal Transient Large-Signal Transient Large-Signal Transient Response, VS = 5V, 0V Response, VS = 5V, 0V Response, VS = 5V, 0V
4V 4V 100mV 2V 2V 50mV 0V 0V 0 AV = +1 20µs/DIV 1013/14 TPC16 AV = +1 10µs/DIV 1013/14 TPC17 AV = +1 10µs/DIV 1013/14 TPC18 RL = 600Ω TO GROUND RL = 4.7k TO 5V NO LOAD INPUT = 0V TO 100mV PULSE INPUT = 0V TO 4V PULSE INPUT = 0V TO 4V PULSE 10134fe 8 For more information www.linear.com/LT1013 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications schematic diagram Package Description Revision History Typical Application Related Parts
