Datasheet ADP2381 (Analog Devices) - 6
Description20 V, 6 A Synchronous Step-Down Regulator with Low-Side Driver
Pages / Page28 / 6 — ADP2381. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTION. PVIN. 16 …
File Format / SizePDF / 857 Kb
ADP2381. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTION. PVIN. 16 BST. UVLO. PGOOD. TOP VIEW. (Not to Scale). VREG. SYNC. PGND. EN/SS
ADP2381 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTION PVIN 16 BST UVLO PGOOD TOP VIEW (Not to Scale) VREG SYNC PGND EN/SS
link to page 13 link to page 13
ADP2381 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTION PVIN 1 16 BST PVIN 2 15 SW UVLO 3 14 SW ADP2381 PGOOD 4 TOP VIEW 13 LD (Not to Scale) RT 5 12 VREG SYNC 6 11 PGND EN/SS 7 10 GND 8 9 COMP FB NOTES 1. THE EXPOSED PAD SHOULD BE SOLDERED
003
TO AN EXTERNAL GROUND PLANE UNDERNEATH THE IC FOR THERMAL DISSIPATION.
10209- Figure 3. Pin Configuration (Top View)
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1, 2 PVIN Power Input. Connect to the input power source and connect a bypass capacitor between this pin and PGND. 3 UVLO Undervoltage Lockout Pin. An external resistor divider can be used to set the turn-on threshold. 4 PGOOD Power-Good Output (Open Drain). A pull-up resistor of 10 kΩ to 100 kΩ is recommended. 5 RT Frequency Setting. Connect a resistor between RT and GND to program the switching frequency between 250 kHz and 1.4 MHz. If the RT pin is connected to GND, the switching frequency is set to 290 kHz. If the RT pin is open, the switching frequency is set to 550 kHz. 6 SYNC Synchronization Input. Connect this pin to an external clock to synchronize the switching frequency between 250 kHz and 1.4 MHz (see the Oscillator section and the Synchronization section for details). 7 EN/SS Enable Pin (EN). When this pin voltage falls below 0.5 V, the regulator is disabled. Soft Start (SS). This pin can also be used to set the soft start time. Connect a capacitor from SS to GND to program the slow soft start time. If this pin is open, the regulator is enabled and uses the internal soft start. 8 COMP Error Amplifier Output. Connect an RC network from COMP to FB. 9 FB Feedback Voltage Sense Input. Connect to a resistor divider from V . OUT 10 GND Analog Ground. Connect to the ground plane. 11 PGND Power Ground. Connect to the source of the synchronous N-channel MOSFET. 12 VREG Internal 8 V Regulator Output. Place a 1 µF ceramic capacitor between this pin and GND. 13 LD Low-Side Gate Driver Output. Connect this pin to the gate of the synchronous N-MOSFET. 14, 15 SW Switch Node Output. Connect this pin to the output inductor. 16 BST Supply Rail for the High-Side Gate Drive. Place a 0.1 µF ceramic capacitor between SW and BST. 17 EPAD The exposed pad should be soldered to an external ground plane underneath the IC for thermal dissipation. Rev. 0 | Page 6 of 28 Document Outline Features Applications Typical Applications Circuit General Description Revision History Specifications Absolute Maximum Ratings Thermal Information ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Functional Block Diagram Theory of Operation Control Scheme Internal Regulator (VREG) Bootstrap Circuitry Low-Side Driver Oscillator Synchronization Enable and Soft Start Power Good Peak Current Limit and Short-Circuit Protection Overvoltage Protection (OVP) Undervoltage Lockout (UVLO) Thermal Shutdown Applications Information Input Capacitor Selection Output Voltage Setting Voltage Conversion Limitations Inductor Selection Output Capacitor Selection Low-Side Power Device Selection Programming Input Voltage UVLO Compensation Design Compensation Network Between COMP and GND Compensation Network Between COMP and FB ADIsimPower Design Tool Design Example Output Voltage Setting Frequency Setting Inductor Selection Output Capacitor Selection Low-Side MOSFET Selection Compensation Components Soft Start Time Program Input Capacitor Selection Schematic of Design Example External Components Recommendation Circuit Board Layout Recommendations Typical Application Circuits Outline Dimensions Ordering Guide
