Datasheet ADP2381 (Analog Devices) - 10
Description20 V, 6 A Synchronous Step-Down Regulator with Low-Side Driver
Pages / Page28 / 10 — ADP2381. Data Sheet. EN/SS. SYNC. VOUT. PGOOD. CH1 2.00V B. CH2 5.00V. …
File Format / SizePDF / 857 Kb
ADP2381. Data Sheet. EN/SS. SYNC. VOUT. PGOOD. CH1 2.00V B. CH2 5.00V. M2.00ms. A CH2 2.00V. CH3 5.00V. CH2 10.0V. M1.00µs. A CH2 7.00V
ADP2381 Data Sheet EN/SS SYNC VOUT PGOOD CH1 2.00V B CH2 5.00V M2.00ms A CH2 2.00V CH3 5.00V CH2 10.0V M1.00µs A CH2 7.00V
ADP2381 Data Sheet EN/SS SYNC 3 3 VOUT 1 SW PGOOD 2 2 IL 4
022 025
CH1 2.00V B CH2 5.00V M2.00ms A CH2 2.00V B W CH3 5.00V CH2 10.0V M1.00µs A CH2 7.00V W CH3 5.00V CH4 5.00A Ω T 49.60%
10209-
T 50.00%
10209- Figure 22. Precharged Output Figure 25. External Synchronization
VOUT (AC) VOUT (AC) 1 1 VIN SW IOUT 3 IL 4 2
023 026
CH1 100mV B M200µs A CH4 2.52 A B B W CH1 20.0mV CH2 10.0V M1.00ms A CH3 13.5V W W CH4 2.00A Ω T 70.20% CH3 5.00V B
10209-
W T 20.20%
10209- Figure 23. Load Transient Response, 1 A to 5 A Figure 26. Line Transient Response, VIN from 10 V to 16 V, IOUT = 6 A
VOUT VOUT 1 1 SW SW 2 2 IL IL 4 4
024
CH1 2.00V B CH2 10.0V M10.00ms A CH1 1.96V
027
W CH1 2.00V B CH2 10.0V M10.00ms A CH1 1.96V CH4 5.00A Ω W T 30.40% CH4 5.00A Ω
10209-
T 60.40%
10209- Figure 24. Output Short Entry Figure 27. Output Short Recovery Rev. 0 | Page 10 of 28 Document Outline Features Applications Typical Applications Circuit General Description Revision History Specifications Absolute Maximum Ratings Thermal Information ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Functional Block Diagram Theory of Operation Control Scheme Internal Regulator (VREG) Bootstrap Circuitry Low-Side Driver Oscillator Synchronization Enable and Soft Start Power Good Peak Current Limit and Short-Circuit Protection Overvoltage Protection (OVP) Undervoltage Lockout (UVLO) Thermal Shutdown Applications Information Input Capacitor Selection Output Voltage Setting Voltage Conversion Limitations Inductor Selection Output Capacitor Selection Low-Side Power Device Selection Programming Input Voltage UVLO Compensation Design Compensation Network Between COMP and GND Compensation Network Between COMP and FB ADIsimPower Design Tool Design Example Output Voltage Setting Frequency Setting Inductor Selection Output Capacitor Selection Low-Side MOSFET Selection Compensation Components Soft Start Time Program Input Capacitor Selection Schematic of Design Example External Components Recommendation Circuit Board Layout Recommendations Typical Application Circuits Outline Dimensions Ordering Guide
