20 V, 6 A Synchronous Step-Down Regulator with Low-Side Driver
Pages / Page
28 /8 — ADP2381. Data Sheet. 4.5. 1.30. 4.4. RISING. 1.25. 4.3. (V). D L. D (. …
PDF / 857 Kb
ADP2381. Data Sheet. 4.5. 1.30. 4.4. RISING. 1.25. 4.3. (V). D L. D (. 4.2. 1.20. ESH. 4.1. R H. HRE 1.15. 4.0. FALLING. IN T. 3.9. O 1.10. PVI. 3.8. 1.05. 3.7. 3.6. 1.00. –40
ADP2381Data Sheet4.51.304.4RISING1.254.3)(V)VRISINGD LD (4.21.20OLHOESH4.1SR HHRE 1.15T4.0OFALLINGIN TVLFALLINGPU3.9O 1.10NLPVIUV3.81.053.73.61.00 010 –40–20020406080100120 013 –40–20020406080100120TEMPERATURE (°C) 10209- TEMPERATURE (°C) 10209- Figure 10. PVIN UVLO Threshold vs. Temperature Figure 13. UVLO Pin Threshold vs. Temperature 3.306063.25604)A)3.20µ (mV (602NTE3.15AG T L O600CURRE3.10-UP L3.05UL598DBACK VPESES3.00F5962.952.90594 011 –40–20020406080100120–40120 014 –20020406080100TEMPERATURE (°C) 10209- TEMPERATURE (°C) 10209- Figure 11. SS Pin Pull-Up Current vs. Temperature Figure 14. FB Voltage vs. Temperature 5308.48.35208.2)510kHzE (V)8.1(G A TNCY500ROSC = 100kΩL8.0UEVOQEG7.9RE490FVR7.84807.74707.6–40120 012 –20020406080100 015 –40–20020406080100120TEMPERATURE (°C) 10209- TEMPERATURE (°C) 10209- Figure 12. Frequency vs. Temperature Figure 15. VREG Voltage vs. Temperature Rev. 0 | Page 8 of 28 Document Outline Features Applications Typical Applications Circuit General Description Revision History Specifications Absolute Maximum Ratings Thermal Information ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Functional Block Diagram Theory of Operation Control Scheme Internal Regulator (VREG) Bootstrap Circuitry Low-Side Driver Oscillator Synchronization Enable and Soft Start Power Good Peak Current Limit and Short-Circuit Protection Overvoltage Protection (OVP) Undervoltage Lockout (UVLO) Thermal Shutdown Applications Information Input Capacitor Selection Output Voltage Setting Voltage Conversion Limitations Inductor Selection Output Capacitor Selection Low-Side Power Device Selection Programming Input Voltage UVLO Compensation Design Compensation Network Between COMP and GND Compensation Network Between COMP and FB ADIsimPower Design Tool Design Example Output Voltage Setting Frequency Setting Inductor Selection Output Capacitor Selection Low-Side MOSFET Selection Compensation Components Soft Start Time Program Input Capacitor Selection Schematic of Design Example External Components Recommendation Circuit Board Layout Recommendations Typical Application Circuits Outline Dimensions Ordering Guide
