Datasheet LTC3672B-2 (Analog Devices) - 2
DescriptionMonolithic Fixed-Output 400mA Buck Regulator with Dual 150mA LDOs in 2mm × 2mm DFN
Pages / Page12 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 3). ORDER …
File Format / SizePDF / 161 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 3). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 3) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3672B-2
V TOP VIEW IN ... –0.3V to 6V V SW 1 8 V IN1, BUCKOUT, ENALL, SW, IN LDO2 ..–0.3V to the Lesser of (V GND 2 7 LDO2 IN + 0.3V) or 6V 9 LDO1 .. –0.3V to the Lesser of (V ENALL 3 6 LDO1 IN1 + 0.3V) or 6V Junction Temperature ... 125°C BUCKOUT 4 5 VIN1 Operating Temperature Range (Note 2).. –40 to 85°C DC PACKAGE Storage Temperature Range ... –65 to 125°C 8-LEAD (2mm s 2mm) PLASTIC DFN TJMAX = 125°C, θJA = 102°C/W, θJC = 20°C/W EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3672BEDC-2#PBF LTC3672BEDC-2#TRPBF LDBH 8-Lead (2mm × 2mm) Plastic DFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = VIN1 = 3.6V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Input Voltage Range l 2.9 5.5 V VUVLO VIN Undervoltage Lockout Threshold VIN Rising 1.7 2 V Undervoltage Lockout Hysteresis 12 100 mV IQ,VIN VIN Quiescent Current (Note 4) All Outputs Enabled, No Load VBUCKOUT = 1.3V 260 400 μA Shutdown VENALL = 0V 1 μA IQ,VIN1 VIN1 Quiescent Current All Outputs Enabled, No Load 2.3 5 μA Shutdown VENALL = 0V 1 μA VIL ENALL Pin Logic Low Voltage l 0.4 V VIH ENALL Pin Logic High Voltage l 1.2 V RENALL ENALL Pin Pulldown Resistance 5.5 MΩ
Synchronous Buck Regulator
fOSC Oscillator Frequency 1.8 2.25 2.7 MHz VBUCKOUT Regulated Output Voltage l 1.17 1.2 1.23 V IMAXP PMOS Switch Maximum Peak Current (Note 5) 550 800 1100 mA IOUT,BUCK Available Output Current 400 mA RP,BUCK PMOS Switch On-Resistance 0.6 Ω RN,BUCK NMOS Switch On-Resistance 0.7 Ω 3672b2fa 2
