Datasheet MAX4322, MAX432, MAX4326, MAX4327, MAX4329 (Maxim) - 5
Manufacturer | Maxim |
Description | Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps |
Pages / Page | 17 / 5 — Single/Dual/Quad, Low-Cost, UCSP/SOT23,. Low-Power, Rail-to-Rail I/O Op … |
Revision | 3 |
File Format / Size | PDF / 510 Kb |
Single/Dual/Quad, Low-Cost, UCSP/SOT23,. Low-Power, Rail-to-Rail I/O Op Amps. MAX4322/MAX4323/MAX4326/MAX4327/MAX4329
Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps MAX4322/MAX4323/MAX4326/MAX4327/MAX4329 __________________________________________Typical Operating Characteristics
(VCC = 5V, VEE = 0V, VCM = VCC/2, SHDN = VCC, TA = +25°C, unless otherwise noted.)
GAIN AND PHASE vs. FREQUENCY POWER-SUPPLY REJECTION RATIO GAIN AND PHASE vs. FREQUENCY (WITH CLOAD) vs. FREQUENCY
MAX4322/26/29-02 MAX4322/26/29-01 60 180 60 180 144 144 0 AV = +1 40 108 40 108 GAIN MAX4322/26/29-03 -20 GAIN 72 72 20 36 20 36 -40 0 0 GAIN (dB) GAIN (dB) PSRR (dB) 0 PHASE -36 0 -36 -60 PHASE (DEGREES) PHASE PHASE (DEGREES) -72 -72 AV = +1000 -80 -20 -108 -20 -108 AV = +1000 RL = ∞ NO LOAD -144 CL = 500pF -144 -100 -40 -180 -40 -180 100 1k 10k 100k 1M 10M 100M 100 1k 10k 100k 1M 10M 100M 10 100 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
MAX4323/MAX4327 MAX4326/MAX4327/MAX4329 OUTPUT IMPEDANCE SHUTDOWN SUPPLY CURRENT CHANNEL SEPARATION vs. FREQUENCY vs. FREQUENCY vs. TEMPERATURE
130 100 60 AV = +1 120 µA) 50 MAX4323-06 VCC = 6.5V MAX4322/26/29-04 MAX4322/26/29-05 110 ) Ω 10 40 100 90 1 30 VCC = 2.7V 80 20 CHANNEL SEPARATION (dB) 70 OUTPUT IMPEDANCE ( 0.1 SHUTDOWN SUPPLY CURRENT ( 10 60 VSHDN = 0V 50 0.01 0 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M 100M -40 -25 -10 5 20 35 50 65 80 95 FREQUENCY (Hz) FREQUENCY (Hz) TEMPERATURE (°C)
SUPPLY CURRENT PER AMPLIFIER INPUT OFFSET VOLTAGE INPUT BIAS CURRENT vs. TEMPERATURE vs. TEMPERATURE vs. COMMON-MODE VOLTAGE
900 3.00 50 SOT23-5/6 850 2.25 40 PACKAGE V MAX4322/26/29-07 MAX4322/26/29-08 30 CC = 2.7V MAX4322/26/29-09 800 1.50 µA) VCC = 6.5V 20 VCC = 6.5V 750 0.75 10 700 0 0 VCC = 2.7V 650 VOLTAGE (mV) -0.75 -10 SUPPLY CURRENT ( -20 600 -1.50 INPUT BIAS CURRENT (nA) SO PACKAGE -30 550 -2.25 -40 500 -3.00 -50 -40 -25 -10 5 20 35 50 65 80 95 -40 -25 -10 5 20 35 50 65 80 95 0 1 2 3 4 5 6 TEMPERATURE (°C) TEMPERATURE (°C) COMMON-MODE VOLTAGE (V)
_______________________________________________________________________________________ 5
