Datasheet ADL5610 (Analog Devices) - 7
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page16 / 7 — Data Sheet. ADL5610. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL …
File Format / SizePDF / 558 Kb
Data Sheet. ADL5610. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter. Rating. Table 4. Thermal Resistance
Data Sheet ADL5610 ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL RESISTANCE Parameter Rating Table 4 Thermal Resistance
link to page 7 link to page 14 link to page 14
Data Sheet ADL5610 ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE Parameter Rating
Table 4 lists the junction-to-air thermal resistance (θJA) and the Supply Voltage, VPOS 6.5 V junction-to-case thermal resistance (θJC) for the ADL5610. Input Power (50 Ω Impedance) 20 dBm Internal Power Dissipation (Pad Soldered to 800 mW
Ground)
Package Type θ 1 2 JA θJC Unit
ESD Human Body Model (HBM) Rating (ESDA/ ±1.5 kV 3-Lead SOT-89 (RK-3) 52 9 °C/W JEDEC JS-001-2011) 1 Measured on the ADL5610 evaluation board. For more information about Maximum Junction Temperature 150°C board layout, see the Soldering Information and Recommended PCB Land Operating Temperature Range −40°C to +105°C Pattern section. 2 Based on simulation with a standard JEDEC board per JESD51. Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum
ESD CAUTION
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 7 of 16 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 6 GHz Frequency Band 30 MHz to 500 MHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
