Datasheet ADL5544 (Analog Devices)
Description | 30 MHz to 6 GHz RF/IF Gain Block |
Pages / Page | 20 / 1 — 30 MHz to 6 GHz. RF/IF Gain Block. Data Sheet. ADL5544. FEATURES. … |
Revision | A |
File Format / Size | PDF / 393 Kb |
30 MHz to 6 GHz. RF/IF Gain Block. Data Sheet. ADL5544. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Fixed gain of 17.4 dB. GND
30 MHz to 6 GHz RF/IF Gain Block Data Sheet ADL5544 FEATURES FUNCTIONAL BLOCK DIAGRAM Fixed gain of 17.4 dB GND Broadband operation from 30 MHz to 6 GHz (2) Input/output internally matched to 50 Ω ADL5544 Integrated bias control circuit OIP3 of 34.9 dBm at 900 MHz BIAS P1dB of 17.6 dBm at 900 MHz 1 2 3
001
Noise figure of 2.9 dB at 900 MHz RFIN GND RFOUT
11384-
Single 5 V power supply
Figure 1.
Low quiescent current of 55 mA Wide operating temperature range of −40°C to +105°C Thermally efficient SOT-89 package ESD rating of ±1.5 kV (Class 1C) GENERAL DESCRIPTION
The ADL5544 is a single-ended RF/IF gain block amplifier The ADL5544 is fabricated on an InGaP HBT process and has that provides broadband operation from 30 MHz to 6 GHz. a high ESD rating of ±1.5 kV (Class 1C). The ADL5544 is also The ADL5544 provides over 34 dBm of OIP3 using only 55 mA ful y specified for operation across the wide temperature range of from a 5 V supply. −40°C to +105°C. A ful y populated RoHS-compliant evaluation The ADL5544 provides a gain of 17 dB, which is stable over board is available. frequency, temperature, power supply, and from device to device. The amplifier is offered in the industry-standard SOT-89 package and is internal y matched to 50 Ω at the input and output, making the ADL5544 very easy to implement in a wide variety of applica- tions. The only external components required are the input/output ac coupling capacitors, power supply decoupling capacitors, and dc bias inductor.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
