Datasheet ADL5544 (Analog Devices) - 5
Description | 30 MHz to 6 GHz RF/IF Gain Block |
Pages / Page | 20 / 5 — Data Sheet. ADL5544. TYPICAL SCATTERING PARAMETERS (S-PARAMETERS). Table … |
Revision | A |
File Format / Size | PDF / 393 Kb |
Data Sheet. ADL5544. TYPICAL SCATTERING PARAMETERS (S-PARAMETERS). Table 2. Frequency. S11. S21. S12. S22. (MHz)
Data Sheet ADL5544 TYPICAL SCATTERING PARAMETERS (S-PARAMETERS)
VPOS = 5 V and TA = 25°C. The effects of the test fixture have been deembedded up to the pins of the device.
Table 2. Frequency S11 S21 S12 S22 (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
30 −9.75838 −92.0495 19.91469 160.691 −21.4134 19.08688 −10.175 −100.818 50 −13.0161 −114.478 18.9406 163.9441 −21.1763 10.75632 −12.7436 −124.228 100 −15.8296 −142.951 18.34431 167.4073 −21.0719 3.454046 −14.8272 −150.688 200 −16.7468 −164.185 18.13374 166.5362 −21.059 −2.10036 −15.7366 −169.056 300 −16.7917 −173.294 18.0488 163.4408 −21.0741 −5.56114 −15.9476 −177.5 400 −16.7639 −178.57 17.97824 159.7115 −21.0901 −8.54887 −15.9985 177.0591 500 −16.6368 176.8142 17.91669 155.6494 −21.1284 −11.3218 −15.9997 172.8508 600 −16.5495 172.727 17.85356 151.5874 −21.1641 −13.9309 −15.9194 169.301 700 −16.4931 169.7664 17.77106 147.4093 −21.2044 −16.5131 −15.8227 166.4768 800 −16.4227 166.4253 17.71131 143.3218 −21.2438 −19.0298 −15.7257 163.7476 900 −16.3553 163.4457 17.66826 139.1424 −21.2871 −21.5022 −15.5947 162.0291 1000 −16.4799 160.784 17.58888 134.9062 −21.3302 −23.9656 −15.6619 160.4644 1100 −16.4953 158.6829 17.53756 130.7521 −21.3803 −26.4082 −15.644 159.4497 1200 −16.7606 157.8074 17.47488 126.5829 −21.4161 −28.8192 −15.8311 159.6244 1300 −16.9103 157.3382 17.44318 122.3575 −21.4674 −31.2788 −15.9907 159.7403 1400 −17.2225 158.2929 17.38821 118.1946 −21.5203 −33.7399 −16.21 160.9107 1500 −17.6402 160.1629 17.33858 114.0765 −21.5672 −36.1081 −16.539 162.8989 1600 −18.0653 164.333 17.32871 109.7247 −21.6024 −38.6986 −16.7579 165.3782 1700 −18.5601 169.5526 17.27848 105.5495 −21.6825 −41.0309 −17.0431 169.2425 1800 −19.01 177.6071 17.22524 101.4425 −21.7323 −43.4108 −17.1957 174.945 1900 −19.1982 −173.627 17.19407 97.28532 −21.7873 −45.7867 −17.2297 −179.104 2000 −19.156 −163.672 17.14779 93.09047 −21.8417 −48.1855 −17.0968 −171.974 2100 −18.7447 −154.484 17.1201 88.86399 −21.8994 −50.5584 −16.8241 −164.872 2200 −18.2725 −146.868 17.06239 84.78041 −21.9604 −52.8879 −16.481 −158.228 2300 −17.5769 −140.357 17.00071 80.71247 −22.0229 −55.1919 −16.0694 −152.253 2400 −16.9363 −136.067 16.97464 76.65373 −22.0831 −57.4478 −15.6966 −147.411 2500 −16.3707 −133.128 16.91632 72.6253 −22.1477 −59.6933 −15.4361 −143.919 2600 −15.8425 −131.025 16.84092 68.6308 −22.2125 −61.938 −15.2228 −141.803 2700 −15.4474 −130.097 16.80102 64.69363 −22.2782 −64.111 −15.209 −141.248 2800 −15.1642 −129.731 16.74106 60.74876 −22.3485 −66.3047 −15.2585 −142.511 2900 −14.9231 −130.057 16.68572 56.76032 −22.4164 −68.5093 −15.3514 −145.642 3000 −14.8791 −130.912 16.64527 52.71256 −22.4858 −70.6726 −15.4628 −150.396 3100 −14.8847 −132.738 16.56622 48.69909 −22.5616 −72.9343 −15.4514 −156.986 3200 −14.9364 −134.966 16.51404 44.62054 −22.636 −75.1868 −15.2627 −164.185 3300 −15.1065 −138.423 16.45702 40.56141 −22.7184 −77.4701 −14.9704 −171.492 3400 −15.2148 −142.265 16.38871 36.48298 −22.8123 −79.8304 −14.4379 −178.173 3500 −15.2414 −147.094 16.3331 32.32549 −22.9021 −82.0942 −13.8431 175.3551 3600 −15.0937 −152.434 16.26873 28.0511 −23.0024 −84.4293 −13.2863 169.8835 3700 −14.8339 −157.56 16.2039 23.84273 −23.1015 −86.7756 −12.7034 164.8455 3800 −14.3558 −162.074 16.11548 19.63339 −23.2085 −89.1254 −12.1263 160.5459 3900 −13.7757 −166.117 16.03442 15.32869 −23.3318 −91.426 −11.5679 156.6935 4000 −13.0504 −169.18 15.92646 11.18556 −23.4494 −93.8454 −10.9616 153.5414 4100 −12.3247 −171.219 15.82941 6.975896 −23.577 −96.1196 −10.3638 151.0243 4200 −11.6347 −173.249 15.72571 2.726895 −23.7138 −98.3778 −9.78722 149.3781 4300 −10.9654 −174.775 15.58441 −1.36477 −23.8541 −100.612 −9.23037 148.452 4440 −10.2422 −176.69 15.44684 −7.08335 −24.0446 −103.673 −8.61459 148.1682 4500 −9.95152 −177.613 15.38641 −9.50947 −24.1234 −104.95 −8.40319 148.3894 4600 −9.51739 −178.831 15.2557 −13.503 −24.2418 −107.053 −8.1407 148.9119 Rev. A | Page 5 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
