20 /10 — ADL5544. Data Sheet. 100 MHz TO 500 MHz FREQUENCY BAND. OIP3. , dB. dB ( …
Revision
A
PDF / 393 Kb
ADL5544. Data Sheet. 100 MHz TO 500 MHz FREQUENCY BAND. OIP3. , dB. dB ( 3. 140MHz. , OIP. GAIN. Bm) d. 350MHz. , P IN. 3 (. P1dB. IP O. , GA E R. FIGU
ADL5544Data Sheet100 MHz TO 500 MHz FREQUENCY BAND3535)OIP3m30, dB33dB ( 325140MHz, OIP31dB201GAINBm) d350MHz, P IN3 (P1dB15IP O29, GA E R10FIGU27E5NOISE FIGUREOIS N0250.100.150.200.250.300.350.400.450.50 009 –12–10–8–6–4–2 012 FREQUENCY (GHz) 1384- P 1 OUT PER TONE (dBm) 1384- 1 Figure 9. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency, Figure 12. OIP3 vs. Output Power (POUT) and Frequency, Low Frequency Configuration Low Frequency Configuration 19.0018.5–5–40°C+25°C18.0) B–1017.5S (dB) d+85°CERS2217.0N (–15AI+105°CMETGAS11R16.5–20S-PA16.0S12–2515.515.0–300.100.150.200.250.300.350.400.450.50 010 0.100.150.200.250.300.350.400.450.50 013 FREQUENCY (GHz) 1384- FREQUENCY (GHz) 1384- 1 1 Figure 10. Gain vs. Frequency and Temperature, Figure 13. Input Return Loss (S11), Output Return Loss (S22), and Reverse Low Frequency Configuration Isolation (S12) vs. Frequency, Low Frequency Configuration 40406.0+25°C–40°C5.535355.03030)+85°CdB+105°C4.5( E2525Bm)Bm)Rdd4.0B (+25°C+85°C3 (+85°CFIGU1d2020IPE+105°CPO3.5OIS N+25°C15153.0–40°C+105°C–40°C10102.5552.0 1 1 0.100.150.200.250.300.350.400.450.50 0 0.100.150.200.250.300.350.400.450.50 014 FREQUENCY (GHz) 1384- FREQUENCY (GHz) 1 11384- Figure 11. P1dB and OIP3 vs. Frequency and Temperature, Figure 14. Noise Figure vs. Frequency and Temperature, Low Frequency Configuration Low Frequency Configuration Rev. A | Page 10 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
