Datasheet ADL5602 (Analog Devices) - 9
Description50 MHz TO 4.0 GHz RF/IF Gain Block
Pages / Page16 / 9 — Data Sheet. ADL5602. TYPICAL PERFORMANCE CHARACTERISTICS. +25°C. ) m. …
File Format / SizePDF / 310 Kb
Data Sheet. ADL5602. TYPICAL PERFORMANCE CHARACTERISTICS. +25°C. ) m. OIP3. –40°C. , d B. ( 3. +85°C. B 22. , OIP. GAIN. d 20. , P. P1dB. , G F. 0.4. 0.8
Data Sheet ADL5602 TYPICAL PERFORMANCE CHARACTERISTICS +25°C ) m OIP3 –40°C , d B ( 3 +85°C B 22 , OIP GAIN d 20 , P P1dB , G F 0.4 0.8
Data Sheet ADL5602 TYPICAL PERFORMANCE CHARACTERISTICS 45 30 45 40 28 40 +25°C ) m 35 OIP3 B 26 35 –40°C , d B 30 d 24 30 ( 3 ) +85°C ) m m 25 B 22 25 B , OIP d (d ( B 3 dB GAIN 20 d 20 20 1 P P1 OI , P P1dB –40°C IN 15 18 15 A +25°C , G F 10 16 10 N +85°C 5 NF 14 5 0 12 0
3 6
0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
00
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
00 0- 0- 19 19
FREQUENCY (GHz)
08
FREQUENCY (GHz)
08 Figure 3. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency Figure 6. P1dB and OIP3 vs. Frequency and Temperature
21.0 44 42 900MHz 20.5 40 700MHz 20.0 350MHz 38 –40°C 19.5 36 ) +25°C ) 2000MHz B 34 19.0 m d B 2600MHz ( d ( 32 IN +85°C 3 18.5 GA 30 OIP 18.0 28 26 17.5 3500MHz 24 17.0 4000MHz 22 140MHz 50MHz 16.5 20 0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
400
–5 –3 –1 1 3 5 7 9 11 13 15 17
07 0- -0
FREQUENCY (GHz)
19
P
90 08
OUT PER TONE (dBm)
81 0 Figure 4. Gain vs. Frequency and Temperature Figure 7. OIP3 vs. Output Power (POUT) and Frequency
0 5.6 –5 5.2 –10 4.8 –15 +85°C B) d B) 4.4 ( S11 d ( –20 RS E E S12 4.0 T UR –25 E +25°C IG F 3.6 AM E –30 AR IS -P 3.2 S –35 NO –40°C 2.8 –40 S22 –45 2.4 –50 2.0
8
05 0
00 0- 0- 19
FREQUENCY (GHz)
19 08
FREQUENCY (GHz)
08 Figure 5. Input Return Loss (S11), Output Return Loss (S22), and Figure 8. Noise Figure vs. Frequency and Temperature Reverse Isolation (S12) vs. Frequency Rev. A | Page 9 of 16 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
