Datasheet ADL5602 (Analog Devices)
Description | 50 MHz TO 4.0 GHz RF/IF Gain Block |
Pages / Page | 16 / 1 — 50 MHz to 4.0 GHz. RF/IF Gain Block. Data Sheet. ADL5602. FEATURES. … |
Revision | A |
File Format / Size | PDF / 310 Kb |
50 MHz to 4.0 GHz. RF/IF Gain Block. Data Sheet. ADL5602. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Fixed gain of 20 dB. GND
50 MHz to 4.0 GHz RF/IF Gain Block Data Sheet ADL5602 FEATURES FUNCTIONAL BLOCK DIAGRAM Fixed gain of 20 dB GND Operation from 50 MHz to 4.0 GHz (2) Highest dynamic range gain block ADL5602 Input/output internally matched to 50 Ω Integrated bias control circuit OIP3 of 42.0 dBm at 2.0 GHz BIAS P1dB of 19.3 dBm at 2.0 GHz 1 2 3
001
Noise figure of 3.3 dB at 2.0 GHz RFIN GND RFOUT
08190-
Single 5 V power supply
Figure 1.
Low quiescent current of 89 mA Thermally efficient SOT-89 package ESD rating of ±1.5 kV (Class 1C) GENERAL DESCRIPTION
The ADL5602 is a broadband 20 dB linear amplifier that operates The ADL5602 is fabricated on an InGaP HBT process and has at frequencies up to 4 GHz. The device can be used in a wide an ESD rating of ±1.5 kV (Class 1C). The device is available in a variety of cel ular, CATV, military, and instrumentation equipment. thermally efficient SOT-89 package. The ADL5602 provides the highest dynamic range available The ADL5602 consumes 89 mA on a single 5 V supply and is from an internally matched gain block. This is accomplished fully specified for operation from −40°C to +85°C. by providing extremely low noise figures and very high OIP3 A fully populated RoHS-compliant evaluation board is available. specifications simultaneously, across the entire 4 GHz frequency range. The ADL5602 provides a gain of 20 dB, which is stable over frequency, temperature, power supply, and from device to device. The device is internally matched to 50 Ω at the input and output, making the ADL5602 very easy to implement in a wide variety of applications. Only input/output ac coupling capacitors, power supply decoupling capacitors, and an external inductor are required for operation.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
