Datasheet HMC740ST89E (Analog Devices) - 8
DescriptionInGaP HBT Active Bias MMIC Amplifier, 0.05 - 3 GHz
Pages / Page8 / 8 — HMC740ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. …
File Format / SizePDF / 675 Kb
HMC740ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. Evaluation PCB
HMC740ST89E InGaP HBT ACTIVE BIAS MMIC AMPLIFIER, 0.05 – 3 GHz Evaluation PCB
HMC740ST89E
v02.0813
8 T M K - S C LO IN B A R & G E IV R S - D R IE LIF
List of Materials for Evaluation PCB 124390 [1]
P The circuit board used in the final application Item Description M should use RF circuit design techniques. Signal J1, J2 PCB Mount SMA Connector A lines should have 50 Ohm impedance while the J3, J4 DC Pin package ground leads and package bottom should C1, C2 470 pF Capacitor, 0402 Pkg. be connected directly to the ground plane similar to C3 100 pF Capacitor, 0402 Pkg. that shown. A sufficient number of via holes should C4 1000 pF Capacitor, 0603 Pkg. be used to connect the top and bottom ground C5 2.2 µF Capacitor Tantalum planes. The evaluation board should be mounted L1 820 nH Inductor, 0603 Pkg. to an appropriate heat sink. The evaluation circuit U1 HMC740ST89E board shown is available from Hittite upon request. PCB [2] 119392 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: FR4 Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e Anry a alog n D d t evic o p es is la be clie o eved rd to e b r e sa: H ccur iattte itae M nd reliic a r bl o e w . H a o v wee C ver, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8 - 8
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
