Datasheet ADL5534 (Analog Devices) - 6
Description20 MHz TO 500 MHz IF Amplifier
Pages / Page16 / 6 — ADL5534. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN1. …
File Format / SizePDF / 435 Kb
ADL5534. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN1. FOU. PIN 1 INDICATOR. NC 1. 12 CLIN1. NC 2. 11 NC. TOP VIEW. NC 3. 10 NC
ADL5534 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN1 FOU PIN 1 INDICATOR NC 1 12 CLIN1 NC 2 11 NC TOP VIEW NC 3 10 NC
ADL5534 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS T1 IN1 FOU RF NC NC R 16 15 14 13 PIN 1 INDICATOR NC 1 12 CLIN1 NC 2 11 NC ADL5534 TOP VIEW NC 3 10 NC (Not to Scale) NC 4 9 NC 5 6 7 8 T2 IN2 NC IN2 RF CL FOU R NOTES 1. NC = NO CONNECT. 2. THE EXPOSED PADDLE IS INTERNALLY
002
CONNECTED TO GND. SOLDER TO A LOW IMPEDANCE GROUND PLANE.
06836- Figure 2. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1, 2, 3, 4, 6, 9, NC No Connect. 10, 11, 14, 15 5, 16 RFIN2, RFIN1 RF Input. Requires a dc blocking capacitor. Use a 10 nF capacitor for normal operation. 7, 12 CLIN2, CLIN1 A 1 nF capacitor connected from Pin 7 to ground and Pin12 to ground provides decoupling for the on-board linearizer. 8, 13 RFOUT2, RFOUT1 RF Output and Bias. DC bias is provided to this pin through an inductor. A 470 nH inductor is recommended for normal operation. The RF path requires a dc blocking capacitor. Use a 10 nF capacitor for normal operation. Exposed Paddle GND. Solder this paddle to a low impedance ground plane. Rev. B | Page 6 of 16 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Using Baluns to Combine Both Amplifiers into a Single Amplifier ADC Driving Application Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
