Datasheet ADL5530 (Analog Devices) - 9
Description | DC to 1000 MHz IF Gain Block |
Pages / Page | 16 / 9 — Data Sheet. ADL5530. 150. 5V, +25°C. 6.0. 5V, –40°C. 140. 5V, +85°C 3.3V, … |
Revision | C |
File Format / Size | PDF / 1.0 Mb |
Data Sheet. ADL5530. 150. 5V, +25°C. 6.0. 5V, –40°C. 140. 5V, +85°C 3.3V, +25°C. 5.5. 3.3V, –40°C. 130. 3.3V, +85°C. 5.0. 120. BLACK = +25°C. d (. 4.5
Data Sheet ADL5530 150 5V, +25°C 6.0 5V, –40°C 140 5V, +85°C 3.3V, +25°C 5.5 3.3V, –40°C 130 A) 3.3V, +85°C 5.0 (m ) T 120 B BLACK = +25°C N d ( 4.5 BLUE = –40°C RE RED = +85°C 110 URE 4.0 CUR IG Y F L 100 E P IS 3.5 UP S NO 90 3.0 80 2.5
17 0 4-
70
583
–6 –4 –2 0 2 4 6 8 10 12 14 16 18 20 22
00
2.0
0 1 34-
0 100 200 300 400 500 600 700 800 900 1000 POUT (dBm)
58 0
FREQUENCY (MHz)
Figure 15. Supply Current vs. POUT and Temperature and Supply, Figure 18. Noise Figure Temperature Distribution, VPOS = 5 V VPOS = 5 V and 3 V
20 20 18 18 16 16 14 ) 14 ) % % E ( 12 E ( 12 G G A A T 10 T 10 EN EN C C 8 8 PER PER 6 6 4 4
15
2
18 0
2
0 4- 4- 583 583
0
0
0
0
30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 15.5 15.9 16.3 16.7 17.1 17.5 17.9 18.3 15.7 16.1 16.5 16.9 17.3 17.7 18.1 18.5 OIP3 (dBm) GAIN (dB)
Figure 16. OIP3 Distribution at 190 MHz, 5 V Figure 19. Gain Distribution at 190 MHz, VPOS = 5 V
18 40 16 35 14 30 ) ) 12 % % 25 E ( E ( G 10 G A A T T 20 EN 8 EN C C 15 PER 6 PER 10 4 2 5
16 19 0 0 4- 4- 583 583
0
0
0
0
20.0 20.4 20.8 21.2 21.6 22.0 22.4 22.8 2.0 2.2 2.4 2.6 2.8 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 20.2 20.6 21.0 21.4 21.8 22.2 22.6 23.0 P1dB (dBm) NOISE FIGURE (dB)
Figure 17. P1dB Distribution at 190 MHz, VPOS = 5 V Figure 20. Noise Figure Distribution at 190 MHz, VPOS = 5 V Rev. C | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
