Datasheet AD8353 (Analog Devices) - 3
Description1 MHz TO 2.7 GHz RF Gain Block
Pages / Page16 / 3 — Data Sheet. AD8353. SPECIFICATIONS. Table 1. Parameter. Test …
RevisionF
File Format / SizePDF / 347 Kb
Data Sheet. AD8353. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8353 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
VS = 3 V, TA = 25°C, 100 nH external inductor between RFOUT and VPOS, ZO = 50 Ω, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
OVERALL FUNCTION Frequency Range 1 2700 MHz Gain f = 900 MHz 19.8 dB f = 1.9 GHz 17.7 dB f = 2.7 GHz 15.6 dB Delta Gain f = 900 MHz, −40°C ≤ TA ≤ +85°C −0.97 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −1.15 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1.34 dB Gain Supply Sensitivity VPOS ± 10%, f = 900 MHz 0.04 dB/V f = 1.9 GHz −0.004 dB/V f = 2.7 GHz −0.04 dB/V Reverse Isolation (S12) f = 900 MHz −35.6 dB f = 1.9 GHz −34.9 dB f = 2.7 GHz −30.3 dB RF INPUT INTERFACE Pin RFIN Input Return Loss f = 900 MHz 22.3 dB f = 1.9 GHz 20.9 dB f = 2.7 GHz 11.2 dB RF OUTPUT INTERFACE Pin RFOUT Output Compression Point f = 900 MHz, 1 dB compression 9.1 dBm f = 1.9 GHz 8.4 dBm f = 2.7 GHz 7.6 dBm Delta Compression Point f = 900 MHz, −40°C ≤ TA ≤ +85°C −1.46 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −1.17 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1 dB Output Return Loss f = 900 MHz 26.3 dB f = 1.9 GHz 16.9 dB f = 2.7 GHz 13.3 dB DISTORTION/NOISE Output Third-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 23.6 dBm f = 1.9 GHz, ∆f = 1 MHz, PIN = −28 dBm 20.8 dBm f = 2.7 GHz, ∆f = 1 MHz, PIN = −28 dBm 19.5 dBm Output Second-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 31.6 dBm Noise Figure f = 900 MHz 5.3 dB f = 1.9 GHz 6 dB f = 2.7 GHz 6.8 dB POWER INTERFACE Pin VPOS Supply Voltage 2.7 3 3.3 V Total Supply Current 35 41 48 mA Supply Voltage Sensitivity 15.3 mA/V Temperature Sensitivity −40°C ≤ TA ≤ +85°C 60 µA/°C Rev. F | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS APPLICATIONS INFORMATION LOW FREQUENCY APPLICATIONS BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
