Datasheet AD8353 (Analog Devices) - 4
Description1 MHz TO 2.7 GHz RF Gain Block
Pages / Page16 / 4 — AD8353. Data Sheet. Table 2. Parameter. Test Conditions/Comments. Min. …
RevisionF
File Format / SizePDF / 347 Kb
AD8353. Data Sheet. Table 2. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8353 Data Sheet Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
AD8353 Data Sheet
VS = 5 V, TA = 25°C, no external inductor between RFOUT and VPOS, ZO = 50 Ω, unless otherwise noted.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
OVERALL FUNCTION Frequency Range 1 2700 MHz Gain f = 900 MHz 19.5 dB f = 1.9 GHz 17.6 dB f = 2.7 GHz 15.7 dB Delta Gain f = 900 MHz, −40°C ≤ TA ≤ +85°C −0.96 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −1.18 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1.38 dB Gain Supply Sensitivity VPOS ± 10%, f = 900 MHz 0.09 dB/V f = 1.9 GHz −0.01 dB/V f = 2.7 GHz −0.09 dB/V Reverse Isolation (S12) f = 900 MHz −35.4 dB f = 1.9 GHz −34.6 dB f = 2.7 GHz −30.2 dB RF INPUT INTERFACE Pin RFIN Input Return Loss f = 900 MHz 22.9 dB f = 1.9 GHz 21.7 dB f = 2.7 GHz 11.5 dB RF OUTPUT INTERFACE Pin RFOUT Output Compression Point f = 900 MHz 8.3 dBm f = 1.9 GHz 8.1 dBm f = 2.7 GHz 7.5 dBm Delta Compression Point f = 900 MHz, −40°C ≤ TA ≤ +85°C −1.05 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −1.49 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1.33 dB Output Return Loss f = 900 MHz 27 dB f = 1.9 GHz 22 dB f = 2.7 GHz 14.3 dB DISTORTION/NOISE Output Third-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 22.8 dBm f = 1.9 GHz, ∆f = 1 MHz, PIN = −28 dBm 20.6 dBm f = 2.7 GHz, ∆f = 1 MHz, PIN = −28 dBm 19.5 dBm Output Second-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 30.3 dBm Noise Figure f = 900 MHz 5.6 dB f = 1.9 GHz 6.3 dB f = 2.7 GHz 7.1 dB POWER INTERFACE Pin VPOS Supply Voltage 4.5 5 5.5 V Total Supply Current 35 42 52 mA Supply Voltage Sensitivity 4.3 mA/V Temperature Sensitivity −40°C ≤ TA ≤ +85°C 45.7 µA/°C Rev. F | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS APPLICATIONS INFORMATION LOW FREQUENCY APPLICATIONS BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
