Datasheet SM8S-Q (Bourns) - 6
ManufacturerBourns
Description6600 W TVS Diodes - VWM 16~43 V - DO-218 Package - AEC-Q101 Compliant
Pages / Page8 / 6 — SM8S-Q Transient Voltage Suppressor Diode Series. Physical …
File Format / SizePDF / 523 Kb
SM8S-Q Transient Voltage Suppressor Diode Series. Physical Specifications. Typical Part Marking. How to Order. SM8S 18 CA - Q
SM8S-Q Transient Voltage Suppressor Diode Series Physical Specifications Typical Part Marking How to Order SM8S 18 CA - Q
Case ...Molded plastic per UL Class 94V-0 Polarity... Cathode band indicates unidirectional device No cathode band indicates bidirectional device PART MANUFACTURER’S
How to Order
NUMBER TRADEMARK
SM8S 18 CA - Q SM8SXXX YYWW
DATE CODE: Package YY = LAST TWO DIGITS OF YEAR SM8S = DO-218 Package WW = WEEK NUMBER Working Peak Reverse Voltage CATHODE BAND 18 = 18 VRWM (Volts) Suffix A = 5 % Tolerance Unidirectional Device CA = 5 % Tolerance Bidirectional Device AEC-Q101 Suffix Q = AEC-Q101 Compliant
Environmental Specifications
Moisture Sensitivity Level ..1 ESD Classification (HBM)... 3B Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
