Datasheet S-35720 (ABLIC) - 7
ManufacturerABLIC
DescriptionPin-selectable Wake-up Timer IC
Pages / Page20 / 7 — WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC. S-35720 Series. …
Revision1.0_00
File Format / SizePDF / 414 Kb
WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC. S-35720 Series. Absolute Maximum Ratings. Table 4. *1. *2. *3
WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC S-35720 Series Absolute Maximum Ratings Table 4 *1 *2 *3
Rev.1.0_00
Item Symbol Applied Pin Absolute Maximum Rating Unit Power supply voltage VDD − VSS − 0.3 to VSS + 6.5 V SET0, SET1 V Input voltage V SS − 0.3 to VSS + 6.5 V IN _______ RST VSS − 0.3 to VDD + 0.3 ≤ VSS + 6.5 V INT
*1
V Output voltage V SS − 0.3 to VSS + 6.5 V OUT INT
*2
VSS − 0.3 to VDD + 0.3 ≤ VSS + 6.5 V Operation ambient temperature
*3
Topr − −40 to +85 °C Storage temperature Tstg − −55 to +150 °C
*1.
S-35720C01I (Nch open-drain output)
*2.
S-35720C02I (CMOS output)
*3.
Conditions with no condensation or frost. Condensation or frost causes short-circuiting between pins, resulting in a malfunction.
Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Recommended Operation Conditions Table 5
(VSS = 0 V) Item Symbol Condition Min. Typ. Max. Unit Operation power supply voltage VDD Ta = −40°C to +85°C 1.8 − 5.5 V
Oscillation Characteristics Table 6
(Ta = +25°C, VDD = 3.0 V, VSS = 0 V unless otherwise specified) (Quartz crystal (NX3215SD, CL = 6.0 pF) manufactured by Nihon Dempa Kogyo Co., Ltd.) Item Symbol Condition Min. Typ. Max. Unit Oscillation start voltage VSTA Within 10 seconds 1.8 − 5.5 V Oscillation start time tSTA − − − 1 s IC-to-IC frequency deviation
*1
δIC − −20 − +20 ppm
*1.
Reference value 7
