Datasheet S-35720 (ABLIC) - 8
ManufacturerABLIC
DescriptionPin-selectable Wake-up Timer IC
Pages / Page20 / 8 — WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC S-35720 Series. DC …
Revision1.0_00
File Format / SizePDF / 414 Kb
WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC S-35720 Series. DC Electrical Characteristics. Table 7. *1. *2
WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC S-35720 Series DC Electrical Characteristics Table 7 *1 *2
Rev.1.0_00
(Ta = −40°C to +85°C, VSS = 0 V unless otherwise specified) (Quartz crystal (NX3215SD, CL = 6.0 pF) manufactured by Nihon Dempa Kogyo Co., Ltd.) Item Symbol Applied Pin Condition Min. Typ. Max. Unit V Current DD = 3.0 V, _______ I RST pin = V − 0.2 0.35 μA consumption 1 DD1 − DD, INT pin = no load High level input _______ I V leakage current IZH SET0, SET1, RST IN = VDD −0.5 − 0.5 μA Low level input I leakage current IZL SET0, SET1 VIN = VSS −0.5 − 0.5 μA High level output I
*1
V leakage current OZH INT OUT = VDD −0.5 − 0.5 μA Low level output I
*2
V leakage current OZL INT OUT = VSS −0.5 − 0.5 μA High level input _______ V − 0.7 × V voltage IH SET0, SET1, RST DD − VSS + 5.5 V Low level input _______ V − V voltage IL SET0, SET1, RST SS − 0.3 − 0.3 × VDD V High level output V voltage OH INT IOH = −0.4 mA 0.8 × VDD − − V Low level output V voltage OL INT IOL = 2.0 mA − − 0.4 V Low level input _______ I V current IL RST DD = 3.0 V, VIN = VSS −100 −30 −5 μA
*1.
S-35720C01I (Nch open-drain output)
*2.
S-35720C02I (CMOS output) 8
