Datasheet L5965 (STMicroelectronics) - 5
Manufacturer | STMicroelectronics |
Description | Multiple power management for automotive vision and radar systems |
Pages / Page | 85 / 5 — L5965. Pins description. No. Pin name. Pin type. Description. DS12567. … |
File Format / Size | PDF / 1.3 Mb |
L5965. Pins description. No. Pin name. Pin type. Description. DS12567. Rev 2. page 5/85
L5965 Pins description No. Pin name Pin type Description
15 BST3 I/O Boot-strap capacitor to supply BUCK3 high-side MOS gate-driver circuitry 16 VIN3 S Input voltage supply for BUCK3 17 PH3 O Switching node BUCK3 18 PGND3 G BUCK3 Power ground 19 VREG3_S I BUCK3 regulated voltage output (to internal voltage monitors) 20 VREG4_S I BUCK4 regulated voltage output (to internal voltage monitors) 21 PGND4 G BUCK4 Power ground 22 PH4 O Switching node BUCK4 23 VIN4 S input voltage supply for BUCK4 24 BST4 I/O Boot-strap capacitor to supply BUCK4 high-side MOS gate-driver circuitry 25 WKUP I Wake up input. Internal 200 kΩ pull-down 26 PH5 O BOOST switching node 27 PGND5 G BOOST Power ground 28 VBOOST_S I BOOST regulated voltage output (to internal voltage monitors) 29 COMP2 I/O BUCK2 Error Amplifier compensation network 30 VREG2_S I BUCK2 regulated voltage output (to internal voltage monitors) 31 PGND2 G BUCK2 Power ground 32 PH2 O Switching node BUCK2 33 VBAT2 S Input voltage supply for BUCK2 34 BST2 I/O Boot-strap capacitor to supply BUCK2 high-side MOS gate-driver circuitry 35 SYNCIN I PWM input frequency for synchronization purpose. Internal current pull-down 36 SYNCOUT O PWM output frequency of inner 2.4M oscillator, or SYNCIN if used 37 WDI I Watchdog input. WDI is trigger input from MCU. Internal current pull-down 38 CSN I SPI: chip select input. Active low. Internal current pull-up 39 DI I SPI: serial data input. Internal current pull-down 40 CLK I SPI: serial clock input. Internal current pull-down 41 DO OD SPI: serial data output 42 RESET_B OD Reset 43 FAULT OD Fault pin detection to MCU 44 DGND G Digital GND 45 SGND G Signal ground for low noise circuitry 46 AGND G Analog GND 47 LDO O Linear regulated output 48 VSLDO S Input voltage supply for LDO
DS12567
Rev 2 page 5/85
Document Outline 1 Overview 1.1 Simplified block diagram 1.2 Functional block diagram 2 Pins description 3 Electrical specifications 3.1 Absolute maximum ratings & operating voltage 3.2 Thermal data 3.2.1 Thermal resistance 3.2.2 Thermal warning and protection 3.3 Electrical characteristics 3.3.1 Electrical characteristic curves 4 Functional description 4.1 Programming by OTP 4.2 Voltage regulators and features description 4.2.1 VREG 4.2.2 Pre regulator BUCK1 4.2.3 Pre regulator BUCK2 4.2.4 Post regulator BUCK3 4.2.5 Post regulator BUCK4 4.2.6 BOOST 4.2.7 LDO 4.2.8 VREF 4.2.9 ADC 4.2.10 Wake up pin (WKUP) 4.2.11 Synchronizing pin (SYNC in/out) 4.2.12 Reset and Fault 4.2.13 Configurable watchdog and reset 4.2.14 Under-Voltage, Over-Voltage and Power-Good 4.2.15 Temperature control and VBATx voltage through internal ADC 4.2.16 Maximum Duty Cycle and Refresh Mode for Buck 4.2.17 Frequency-Hopping Spread Spectrum 5 SPI format and register mapping 5.1 SPI frame CRC generator 5.2 SPI registers mapping 5.2.1 SPI REG BUCK1 5.2.2 SPI REG BUCK2 5.2.3 SPI REG WD_REC_EN 5.2.4 SPI REG BUCK4 5.2.5 SPI REG BOOST VREF 5.2.6 SPI REG BUCK EN 5.2.7 SPI REG WD 5.2.8 SPI REG BUCK STAT1 5.2.9 SPI REG BUCK STAT2 5.2.10 SPI REG Fault Table PWUP 5.2.11 SPI REG ADC TH1 5.2.12 SPI REG ADC TH2 5.2.13 SPI REG ADC TH3 5.2.14 SPI REG ADC TH4 5.2.15 SPI REG ADC TH5 5.2.16 SPI REG ADC TH6 5.2.17 SPI REG ADC TH7 5.2.18 SPI REG ADC VBAT1 5.2.19 SPI REG ADC VBAT2 5.2.20 SPI REG OT Warning 5.2.21 SPI Fault STAT 5.2.22 SPI Silicon Version 5.2.23 SPI Device Identification 6 Device operating mode 6.1 Shutdown mode 6.2 Standby mode 6.3 INIT mode 6.4 REC mode 6.5 RAMPUP MAIN and SEC_UP 6.6 ACTIVE mode 6.7 OTP program mode 6.8 OTP bit mapping and register configuration 6.9 OTP (SAF) registers 6.9.1 SAF_REG_OP 6.9.2 SAF_REG_CFG 6.9.3 SAF_REG_DI 6.9.4 SAF_REG_D0_Bit_Ts 6.9.5 SAF_REG_STAT 6.10 Power down phase 6.11 Power up programming 7 Functional safety requirements 7.1 Functions and safety mechanism related to safety requirements 7.2 System safety mechanism 8 Application information 8.1 External components calculation 8.1.1 BUCK1 controller 8.1.1.1 RSENSE 8.1.1.2 BUCK1 output inductor 8.1.1.3 BUCK1 output capacitor 8.1.1.4 BUCK1 bootstrap capacitor 8.1.1.5 BUCK1 compensation network 8.1.2 BUCK2 controller 8.1.2.1 BUCK2 output inductor 8.1.2.2 BUCK2 output capacitor 8.1.2.3 BUCK2 compensation network 8.1.3 BUCK3, BUCK4 8.1.3.1 Output inductor and capacitor 8.1.3.2 Bootstrap capacitor for BUCK3 and BUCK4 8.1.3.3 Input capacitor 8.1.4 BOOST 8.1.4.1 BOOST output inductor 8.1.4.2 BOOST output capacitor 8.1.4.3 BOOST compensation network 8.1.4.4 Output diode for the BOOST converter 8.1.4.5 Input capacitor selection 8.2 PCB Layout example (BUCK1 as main regulator) 9 Package information 9.1 VFQFPN-48 (7x7x1.0 mm - opt. D) package information 9.2 VFQFPN-48 (7x7x1.0) marking information Revision history
