Datasheet ADUM3123 (Analog Devices) - 9
DescriptionIsolated Precision Gate Driver, 4 A Output
Pages / Page15 / 9 — Data Sheet. ADuM3123. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VDD1 …
File Format / SizePDF / 493 Kb
Data Sheet. ADuM3123. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VDD1 1. VDD2. TOP VIEW. DISABLE. NIC. (Not to Scale). GND1 4. GND2
Data Sheet ADuM3123 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD1 1 VDD2 TOP VIEW DISABLE NIC (Not to Scale) GND1 4 GND2
Data Sheet ADuM3123 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD1 1 8 VDD2 V ADuM3123 2 V I 7 O TOP VIEW DISABLE 3 6 NIC (Not to Scale) GND1 4 5 GND2
003
NIC = NOT INTERNALLY CONNECTED
12574- Figure 3. Pin Configuration
Table 11. Pin Function Descriptions Pin No. Mnemonic Description
1 VDD1 Supply Voltage for Isolator Side 1. 2 VI Gate Drive Input. 3 DISABLE Disable. Connect to Logic Low to Enable. 4 GND1 Ground 1. Ground reference for Isolator Side 1. 5 GND2 Ground 2. Ground reference for Isolator Side 2. 6 NIC Not Internally Connected. 7 VO Gate Drive Output. 8 VDD2 Supply Voltage for Isolator Side 2. Rev. 0 | Page 9 of 15 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety Related Specifications Regulatory Information DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Printed Circuit Board (PCB) Layout Propagation Delay Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide
