Datasheet ADuM3223/ADuM4223 (Analog Devices) - 9
Description5 KV rms Isolated Precision Half-Bridge Driver, 4 A Output
Pages / Page20 / 9 — Data Sheet. ADuM3223/ADuM4223. ABSOLUTE MAXIMUM RATINGS. Table 11. …
RevisionJ
File Format / SizePDF / 538 Kb
Data Sheet. ADuM3223/ADuM4223. ABSOLUTE MAXIMUM RATINGS. Table 11. Parameter. Symbol. Rating. ESD CAUTION
Data Sheet ADuM3223/ADuM4223 ABSOLUTE MAXIMUM RATINGS Table 11 Parameter Symbol Rating ESD CAUTION
link to page 8 link to page 8
Ambient temperature = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum
Table 11.
Ratings may cause permanent damage to the product. This is a
stress rating only; functional operation of the product at these Storage Temperature TST −55°C to +150°C or any other conditions above those indicated in the operational Operating Junction TJ −40°C to +150°C section of this specification is not implied. Operation beyond Temperature the maximum operating conditions for extended periods may Supply Voltages1 VDD1 −0.5 V to +7.0 V affect product reliability. VDDA, VDDB −0.5 V to +20 V
ESD CAUTION
Input Voltage1 VIA, VIB, −0.5 V to VDD1 + 0.5 V DISABLE Output Voltage1 VOA −0.5 V to VDDA + 0.5 V VOB −0.5 V to VDDB + 0.5 V Average Output IO −35 mA to +35 mA Current, per Pin2 V OA to GNDA Negative VOA −2 V for 100 ns Transient4 VOB to GNDB Negative VOB −2 V for 100 ns Transient4 Common-Mode CMH, CML −100 kV/µs to +100 kV/µs Transients3 1 All voltages are relative to their respective ground. 2 See Figure 2 and Figure 3 for information on maximum allowable current for various temperatures. 3 Refers to common-mode transients across the insulation barrier. Common- mode transients exceeding the absolute maximum rating can cause latch-up or permanent damage. 4 Applies to non-automotive grade parts only. Rev. J | Page 9 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety-Related Specifications ADuM3223 ADuM4223 Regulatory Information DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information PC Board Layout Propagation Delay-Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics Boot-Strapped Half-Bridge Operation DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
