Datasheet ADUM5230 (Analog Devices) - 6
DescriptionIsolated Half-Bridge Driver with Integrated High-Side Supply
Pages / Page15 / 6 — ADuM5230. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter. …
RevisionC
File Format / SizePDF / 779 Kb
ADuM5230. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter. Rating. Table 7. Maximum Continuous Working Voltage1. Max. Unit
ADuM5230 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 6 Parameter Rating Table 7 Maximum Continuous Working Voltage1 Max Unit
link to page 14
Ambient temperature = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum
Table 6.
Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational Storage Temperature (TST) −55°C to +150°C section of this specification is not implied. Operation beyond Ambient Operating Temperature (TA) −40°C to +105°C the maximum operating conditions for extended periods may Input Supply Voltage (VDD1)1 −0.5 V to +7.0 V affect product reliability. Channel B Supply Voltage (VDDB)1 −0.5 V to +27 V Input Voltage (VIA, VIB)1 −0.5 V to VDDI + 0.5 V Output Voltage (VOA, VOB)1 −0.5 V to VISO + 0.5 V, −0.5 V to V
DDB + 0.5 V Input-Output Voltage2 −700 V
Parameter Max Unit Constraint
PEAK to +700 VPEAK Output Differential Voltage3 700 V AC Voltage PEAK Output DC Current (I Bipolar Waveform 424 V peak OA, IOB) −20 mA to +20 mA 50-year minimum Common-Mode Transients4 −100 kV/µs to +100 kV/µs lifetime Unipolar Waveform 1 All voltages are relative to their respective ground. Basic Insulation 600 V peak 50-year minimum 2 Input-to-output voltage is defined as GNDISO − GND1 or GNDB − GND1. lifetime 3 Output differential voltage is defined as GNDISO − GNDB. 4 Refers to common-mode transients across any insulation barrier. Common- DC Voltage mode transients exceeding the Absolute Maximum Ratings may cause Basic Insulation 600 V peak 50-year minimum latch-up or permanent damage. lifetime 1 Refers to continuous voltage magnitude imposed across the isolation barrier. See the Insulation Lifetime section for more details.
ESD CAUTION
Rev. C | Page 6 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFOMANCE CHARACTERISTICS APPLICATIONS INFORMATION THEORY OF OPERATION PRINTED CIRCUIT BOARD (PCB) LAYOUT THERMAL ANALYSIS PROPAGATION DELAY-RELATED PARAMETERS DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION INCREASING AND DECREASING AVAILABLE POWER COMMON-MODE TRANSIENT IMMUNITY TYPICAL APPLICATION USAGE INSULATION LIFETIME OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
