Datasheet ADAR7251 (Analog Devices) - 6
Description4-Channel, 16-Bit, Continuous Time Data Acquisition ADC
Pages / Page72 / 6 — ADAR7251. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 4.4 Mb
ADAR7251. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. DIGITAL INPUT/OUTPUT. Table 2. Parameter Symbol. Test
ADAR7251 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit DIGITAL INPUT/OUTPUT Table 2 Parameter Symbol Test
ANALOG INPUT Full-Scale Differential Voltage Gain = 0 dB (LNA and PGA bypass) 5.6 V p-p Gain = 9 dB 1.987 V p-p Gain = 15 dB 0.995 V p-p Gain = 21 dB 0.498 V p-p Gain = 27 dB 249 mV p-p Gain = 33 dB 124 mV p-p Gain = 39 dB 62 mV p-p Gain = 45 dB 31 mV p-p Common-Mode Rejection Ratio (CMRR) At 1 kHz 68 dB Gain Error −0.8 +0.8 dB Input Resistance Single-ended 2860 Ω Differential 5720 Ω VOLTAGE REFERENCE IN/OUT (VREF) At the CM pin 1.5 V CONVERSION SAMPLE RATE Sample Rate 0.3 1.2 1.8 MSPS Input Signal Bandwidth 150 600 900 kHz PLL Input Frequency 16 54 MHz Output Frequency (Internal) 115.2 MHz Lock Time 1 ms LDO REGOUT_DIGITAL Output Voltage Used for internal digital core only 1.8 V Line Regulation AVDDx as an input 2.97 3.3 3.63 V Load Regulation Used for internal digital core only 1 % AUXILIARY ADC Full-Scale Input 3.3 V p-p Sample Rate 112.5 450 kHz Resolution 8 bits INL 0.5 LSB DNL 1 LSB Input Resistance1 Switched capacitor input at a switching 1.2 MΩ frequency of 112.5 kHz 1 From simulation.
DVDDx = 1.8 V, IOVDDx = 3.3 V, CLOAD = 22 pF.
Table 2. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT VOLTAGE High Level VIH 0.7 × IOVDDx V Low Level VIL 0.3 × IOVDDx V OUTPUT VOLTAGE High Level VOH IOH = 1 mA IOVDDx − 0.60 V Low Level VOL IOL = 1 mA 0.4 V INPUT CAPACITANCE 5 pF INPUT LEAKAGE CURRENT ±10 μA Rev. 0 | Page 6 of 72 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Analog Channel Digital Input/Output Power Supply Digital Filter SPI Port Timing Serial/Peripheral Parallel Interface (PPI) Port Timing Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Low Speed Ramp Radar Analog Front End Main Channel Overview Σ-∆ Modulation and Digital Filtering Differential Input Configuration High-Pass Filter (HPF) Low-Pass Filter (LPF) Input Routing Equalizer (EQ) Using LNA/PGA, EQ, or the Input Capacitor Reference Auxiliary ADC Power Supply LDO Clock Requirements Crystal Oscillator PLL Integer Mode Fractional Mode PLL Lock Acquisition GPIO ADC Data Port ADC Serial Mode ADC Serial Master Mode ADC Serial Master Mode with ADC Serial Slave ADC PPI (Byte Wide Mode) ADC PPI Nibble Wide Mode DAQ Mode Using Multiple ADAR7251 Devices for Systems with More Than Four Channels Device Address R/ Register Address Data Bytes CRC PCB Layout Guidelines Register Summary Register Details Clock Control Register PLL Denominator Register PLL Numerator Register PLL Control Register PLL Status Register Master Enable Switch Register ADC Enable Register Power Enable Register Clear the ASIL errors Register Selects Which Errors to Mask Register ASIL Error Flag Register ASIL Error Code Register CRC Value, Bits[7:0] Register CRC Value Register Start Calculating the CRC Value of the Register Map Content Register Register Map CRC Calculation Done Register Register Map CRC Value, Bits[7:0] Register Register Map CRC Value, Bits[15:8] Register Low Noise Amplifier Gain Control Register Programmable Gain Amplifier Gain Control Register Signal Path for ADC 1 Through ADC 4 Register Decimator Rate Control Register High Pass Filter Control Register DAQ Mode Control Register Decimator Truncate Control Register Serial Output Port Control Register Parallel Port Control Register ADC Digital Output Mode Register Auxiliary ADC Read Value Registers Auxiliary ADC Sample Rate Selection Register Auxiliary ADC Mode Register MPx Pin Modes Registers MP Write Value Registers MP Read Value Registers SPI_CLK Pin Drive Strength and Slew Rate Register SPI_MISO Pin Drive Strength and Slew Rate Register Pin Drive Strength and Slew Rate Register SPI_MOSI Pin Drive Strength and Slew Rate Register ADDR15 Pin Drive Strength and Slew Rate Register Pin Drive Strength and Slew Rate Register FS_ADC Pin Drive Strength and Slew Rate Register Pin Drive Strength and Slew Rate Register SCLK_ADC Pin Drive Strength and Slew Rate Register ADC_DOUTx Pins Drive Strength and Slew Rate Registers DATA_READY Pin Drive Strength and Slew Rate Register XTAL Enable and Drive Register ADC Test Register Digital Filter Sync Enable Register CRC Enable/Disable Register Typical Application Circuit Outline Dimensions Ordering Guide Automotive Products
