AD7176-2Key Sheet DOUT/RDY returns high until the next conversion is available. If several channels are enabled, the ADC automatical y In this mode, the data can be read only once. If multiple ADC sequences through the enabled channels and performs a channels are enabled, each channel is output in turn, with the conversion on each channel. When a conversion is started, status bits being appended to the data if DATA_STAT is set in DOUT/RDY goes high and remains high until a valid conversion the interface mode register. The status register indicates the is available and CS is low. As soon as a conversion is available, channel to which the conversion corresponds. DOUT/RDY goes low. The ADC then selects the next channel CS and begins another conversion. The user can read the present conversion while the next conversion is being performed. The two LSBs of the status register indicate the channel to which the DIN conversion corresponds. CSDOUT/RDYDATADATADATADATAREQUEST 007 DINSCLK 11266- Figure 5. Continuous Read Mode DATADOUT/RDYSingle Conversion Mode In single conversion mode, the AD7176-2 performs a single 005 SCLK conversion and is placed in standby mode after the conversion 11266- is complete. DOUT/RDY goes low to indicate the completion of a Figure 6. Single Conversion Mode conversion. When the data-word has been read from the data register, DOUT/RDY goes high. The data register can be read several times, if required, even when DOUT/RDY has gone high. TYPICAL APPLICATION DIAGRAMGPIO0 AND GPIO1OUTPUT HIGH = AVDDGPIO0OUTPUT LOW = AVSSGPIO1FOR SINGLE SUPPLYCASE OUTPUT HIGH = 5VOUTPUT LOW = GND16MHz1920GPIO0GPIO1CX1CX2OPTIONAL EXTERNALXTAL1 9CRYSTAL CIRCUITRY21 AIN0CAPACITORSIN0CLKI0/XTAL2 10CLKINOPTIONALDOUT/RDY 11DOUT/RDYEXTERNAL CLOCK22 AIN1INPUTIN112DINDININ213SCLK23 AIN2SCLKCS 14CSIN324 AIN3SYNC/ERROR 15SYNC/ERRORAD7176-2IOVDDIN4AIN41IOVDD 16AIN40.1µFDGND 1713REGCAPD 18VINTPNC0.1µF1µFAVDD12VNC 7IN4.7µF0.1µFAVDD1 7ADR445BRZ0.1µFAVDD24GNDVOUT 63REF+AVDD2 80.1µF4.7µF0.1µFTRIMTP0.1µF582REF–REGCAPA 54REFOUT2.5V REFERENCEAVSS0.1µF1µF0.1µFOUTPUT6 006 11266- Figure 7. Typical Application Diagram Rev. 0 | Page 4 of 6 Document Outline General Description Features and Benefits Key Characteristics Fundamental Specifications Noise Operating the AD7176-2 Data Interface Accessing the ADC Register Map ADC and Interface Mode Configuration ADC Mode Register Interface Mode Register Data Modes Continuous Conversion Mode (Default) Continuous Read Mode Single Conversion Mode Typical Application Diagram Frequently Asked Questions Learn More and Start Designing Compatible Devices Package Diagram Getting Started
