Datasheet ADA4625-1, ADA4625-2 (Analog Devices) - 9
Description | 36 V, 18 MHz, Low Noise, Fast Settling Single Supply, RRO, JFET Op Amp |
Pages / Page | 35 / 9 — Data Sheet. ADA4625-1/. ADA4625-2. TYPICAL PERFORMANCE CHARACTERISTICS. … |
Revision | A |
File Format / Size | PDF / 1.3 Mb |
Data Sheet. ADA4625-1/. ADA4625-2. TYPICAL PERFORMANCE CHARACTERISTICS. VSY = ±18V. SY = 5V. L = ∞. VCM = 1.5V. RL = ∞. PLIFIERS. F AM. R O
Data Sheet ADA4625-1/ ADA4625-2 TYPICAL PERFORMANCE CHARACTERISTICS
TA = 25°C, VCM = 0 V, unless otherwise noted.
50 25 VSY = ±18V V R SY = 5V L = ∞ VCM = 1.5V RL = ∞ 40 20 PLIFIERS 30 15 PLIFIERS F AM F AM R O 20 R O 10 BE BE NUM NUM 10 5 0 0 –100 –75 –50 –25 0 25 50 75 100
003
–400 –300 –200 –100 0 100 200 300 400
006
VOS (µV) V
15893-
OS (µV)
15893- Figure 5. Input Offset Voltage (VOS) Distribution, Supply Voltage (VSY) = ±18 V Figure 8. VOS Distribution, VSY = 5 V
70 45 VSY = ±18V VSY = 5V 40 VCM = 1.5V 60 35 50 30 PLIFIERS 40 PLIFIERS 25 F AM F AM 20 R O 30 R O BE BE 15 20 NUM NUM 10 10 5 0 0 –2.0 –1.5 –1.0 –0.5 0.0 0.5 1.0 1.5 2.0
004
007
TCVOS (µV/°C)
15893-
TCVOS (µV/°C)
15893- Figure 6. Input Offset Voltage Drift (TCVOS) Distribution (−40°C to +125°C ), Figure 9. TCVOS Distribution (−40°C to +125°C ), VSY = 5 V VSY = ±18 V
1000 600 VSY = 5V VSY = ±18V 800 90 AMPLIFIERS 90 AMPLIFIERS 400 600 400 200 200 (µV) 0 (µV) 0 V OS –200 V OS –200 –400 –600 –400 –800 –1000 –600 –0.2 0.2 0.6 1.0 1.4 1.8 2.2 2.6 3.0 3.4
008
–18.2 –13.2 –8.2 –3.2 1.8 6.8 11.8 16.8
005
VCM (V)
15893-
VCM (V)
15893- Figure 10. VOS vs. VCM, VSY = 5 V Figure 7. VOS vs. Common-Mode Voltage (VCM), VSY = ±18 V Rev. A | Page 9 of 35 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±18 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT AND GAIN STAGES OUTPUT STAGE NO PHASE INVERSION SUPPLY CURRENT APPLICATIONS INFORMATION ACTIVE LOOP FILTER FOR PHASE-LOCKED LOOPS (PLLS) PLL Basic Loop Filter ADA4625-1 ADVANTAGES AND DESIGN EXAMPLE TRANSIMPEDANCE AMPLIFIER Design Example DAC OUTPUT DRIVER RECOMMENDED POWER SOLUTION INPUT OVERVOLTAGE PROTECTION DRIVING CAPACITIVE LOADS THERMAL MANAGEMENT TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
