Datasheet RH1078M (Analog Devices)
DescriptionMicropower, Dual, Single Supply Precision Op Amp
Pages / Page8 / 1 — DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. …
RevisionG
File Format / SizePDF / 161 Kb
DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. OBSOLETE PACKAGE. For Reference Only. BURN-IN CIRCUIT
Datasheet RH1078M Analog Devices, Revision: G
RH1078M Micropower, Dual, Single Supply Precision Op Amp
DESCRIPTION ABSOLUTE MAXIMUM RATINGS
The RH1078M is a micropower dual op amp in the stan- Supply Voltage ... ±22V dard 8-pin configuration. This device is optimized for Differential Input Voltage .. ±30V single supply operation at 5V. Specifications for ±15V Input Voltage .. Equal to Positive Supply Voltage are also provided. 0.5V Below Negative Supply Voltage Output Short-Circuit Duration ... Indefinite The wafer lots are processed to ADI’s in-house Class S flow Operating Temperature Range ... –55°C to 125°C to yield circuits usable in stringent military applications. Storage Temperature Range ... –55°C to 150°C All registered trademarks and trademarks are the property of their respective owners. Lead Temperature (Soldering, 10 sec) .. 300°C
TOP VIEW TOP VIEW TOP VIEW V+ OUT A 1 8 V+ 8 OUT A 1 10 V+ –IN A 2 7 OUT B OUT A 1 7 OUT B –IN A 2 9 OUT B +IN A 3 6 –IN B –IN A 2 6 –IN B +IN A 3 8 –IN B V– 4 5 +IN B NC 4 7 +IN B +IN A 3 5 +IN B J8 PACKAGE 4 V– 5 6 NC 8-LEAD CERAMIC DIP V– W PACKAGE
OBSOLETE PACKAGE
H PACKAGE 10-LEAD CERPAC
For Reference Only
8-LEAD TO-5 METAL CAN
BURN-IN CIRCUIT TOTAL DOSE BIAS CIRCUIT
(Each Amplifier) 10k 50k 15V 20V – – 100Ω 10k + + 8V 50k –15V –20V
Note: For ordering information contact LTC.
Rev. G Document Feedback For more information www.analog.com 1 Document Outline Description Package/Order Information Burn-In Circuit Total Dose Bias Circuit Absolute Maximum Ratings Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Table 2: Electrical Test Requirements Typical Applications Revision History
