Datasheet RH1078M (Analog Devices) - 3
DescriptionMicropower, Dual, Single Supply Precision Op Amp
Pages / Page8 / 3 — TABLE 1: ELECTRICAL CHARACTERISTICS. (Preirradiation). VS = ±15V unless …
RevisionG
File Format / SizePDF / 161 Kb
TABLE 1: ELECTRICAL CHARACTERISTICS. (Preirradiation). VS = ±15V unless otherwise specified. TA = 25°C
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) VS = ±15V unless otherwise specified TA = 25°C
RH1078M
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) VS = ±15V unless otherwise specified. TA = 25°C SUB- –55°C ≤ TA ≤ 125°C SUB- SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX GROUP MIN TYP MAX GROUP UNITS
VOS Input Offset Voltage 350 4 600 2, 3 µV ∆VOS Average Tempco of Offset 0.6 µV/°C ∆Temp Voltage IOS Input Offset Current 0.8 1 1.5 2, 3 nA IB Input Bias Current 15 18 2, 3 nA Input Voltage Range 13.5 1 V –15.0 1 V CMRR Common Mode Rejection VCM = 13.5V, –15V 97 1 dB Ratio VCM = 13V, –14.9V 90 2, 3 dB PSRR Power Supply Rejection VS = 5V, 0V to ±18V 100 1 94 2, 3 dB Ratio AVOL Large-Signal Voltage Gain VO = ±10V, RL = 50k 1000 1 V/mV VO = ±10V, RL = 2k 300 1 V/mV VO = ±10V, RL = 5k 150 2, 3 V/mV VOUT Output Voltage Swing RL = 50k ±13 4 V RL = 2k ±11 4 V RL = 5k ±11 5, 6 V SR Slew Rate 0.06 4 V/µs IS Supply Current per Amplifier 100 1 125 2, 3 µA
Note 1:
All noise parameters are for VS = ±2.5V, VO = 0V.
Note 3:
Power supply rejection ratio is measured at the minimum supply
Note 2:
This parameter is guaranteed by design, characterization or voltage. The op amps actually work at 1.8V supply but with a typical offset correlation to other tested parameters. skew of –300µV. Rev. G For more information www.analog.com 3 Document Outline Description Package/Order Information Burn-In Circuit Total Dose Bias Circuit Absolute Maximum Ratings Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Table 2: Electrical Test Requirements Typical Applications Revision History
