Data SheetAD8285ABSOLUTE MAXIMUM RATINGS Table 5. Stresses at or above those listed under Absolute Maximum Parameter Rating Ratings may cause permanent damage to the product. This is a Electrical stress rating only; functional operation of the product at these AVDD18x1 to GND −0.3 V to +2.0 V or any other conditions above those indicated in the operational AVDD33x2 to GND −0.3 V to +3.5 V section of this specification is not implied. Operation beyond DVDD18x3 to GND −0.3 V to +2.0 V the maximum operating conditions for extended periods may DVDD33x4 to GND −0.3 V to +3.5 V affect product reliability. Analog Inputs −0.3 V to +3.5 V ESD CAUTION INx+, INx− to GND Auxiliary Inputs −0.3 V to +2.0 V INADC+, INADC− to GND Digital Outputs −0.3 V to +3.5 V D[11:0], DSYNC, SDIO to GND CLK+, CLK− to GND −0.3 V to +3.9 V PDWN, SCLK, CS, AUX, MUXA, −0.3 V to +3.9 V ZSEL to GND RBIAS, VREF to GND −0.3 V to +2.0 V Environmental Operating Temperature −40°C to +105°C Range (Ambient) Storage Temperature −65°C to +150°C Range (Ambient) Maximum Junction 150°C Temperature Lead Temperature 300°C (Soldering, 10 sec) 1 AVDD18x = AVDD18 and AVDD18ADC. 2 AVDD33x = AVDD33A, AVDD33B, AVDD33C, AVDD33D, and AVDD33REF. 3 DVDD18x = DVDD18, DVDD18CLK. 4 DVDD33x = DVDD33, DVDD33SPI, DVDD33CLK, DVDD33DRV. Rev. B | Page 7 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RADAR RECEIVE PATH AFE CHANNEL OVERVIEW Low Noise Amplifier (LNA) Recommendation Antialiasing Filter (AAF) Mux and Mux Controller ADC CLOCK INPUT CONSIDERATIONS CLOCK DUTY CYCLE CONSIDERATIONS CLOCK JITTER CONSIDERATIONS SDIO PIN SCLK PIN CS\ PIN RBIAS PIN VOLTAGE REFERENCE POWER AND GROUND RECOMMENDATIONS EXPOSED PADDLE THERMAL HEAT SLUG RECOMMENDATIONS SERIAL PERIPHERAL INTERFACE (SPI) HARDWARE INTERFACE MEMORY MAP READING THE MEMORY MAP TABLE LOGIC LEVELS RESERVED LOCATIONS DEFAULT VALUES APPLICATION DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
