Datasheet AD8283 (Analog Devices) - 7
DescriptionRadar Receive Path AFE: 6-Channel LNA/PGA/AAF with ADC
Pages / Page27 / 7 — Data Sheet. AD8283. ABSOLUTE MAXIMUM RATINGS Table 5. With. Parameter. …
RevisionC
File Format / SizePDF / 604 Kb
Data Sheet. AD8283. ABSOLUTE MAXIMUM RATINGS Table 5. With. Parameter. Respect To. Rating. ESD CAUTION
Data Sheet AD8283 ABSOLUTE MAXIMUM RATINGS Table 5 With Parameter Respect To Rating ESD CAUTION
Data Sheet AD8283 ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses at or above those listed under Absolute Maximum
With
Ratings may cause permanent damage to the product. This is a
stress rating only; functional operation of the product at these Electrical or any other conditions above those indicated in the operational AVDD18x GND −0.3 V to +2.0 V section of this specification is not implied. Operation beyond AVDD33x GND −0.3 V to +3.5 V the maximum operating conditions for extended periods may DVDD18x GND −0.3 V to +2.0 V affect product reliability. DVDD33x GND −0.3 V to +3.5 V Analog Inputs GND −0.3 V to +3.5 V INx+, INx−
ESD CAUTION
Auxiliary Inputs GND −0.3 V to +2.0 V INADC+, INADC- Digital Outputs GND −0.3 V to +3.5 V D[11:0], DSYNC, SDIO CLK+, CLK− GND −0.3 V to +3.9 V PDWN, SCLK, CS, AUX, GND −0.3 V to +3.9 V MUXA, ZSEL RBIAS, VREF GND −0.3 V to +2.0 V Environmental Operating Temperature −40°C to +105°C Range (Ambient) Storage Temperature −65°C to +150°C Range (Ambient) Maximum Junction 150°C Temperature Lead Temperature 300°C (Soldering, 10 sec) Rev. C | Page 7 of 27 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications AC Specifications Digital Specifications Switching Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Radar Receive Path AFE Channel Overview Low Noise Amplifier (LNA) Recommendation Antialiasing Filter (AAF) Mux and Mux Controller ADC Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations SDIO Pin SCLK Pin CS Pin RBIAS Pin Voltage Reference Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Serial Peripheral Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Logic Levels Reserved Locations Default Values Application Diagrams Outline Dimensions Ordering Guide Automotive Products
