Datasheet ADR441-EP (Analog Devices) - 3
DescriptionUltralow Noise, LDO XFET® 2.5V Voltage Reference w/Current Sink and Source
Pages / Page8 / 3 — Enhanced Product. ADR441-EP. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. …
File Format / SizePDF / 160 Kb
Enhanced Product. ADR441-EP. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Test Conditions/Comments. Min
Enhanced Product ADR441-EP SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Test Conditions/Comments Min
VIN = 3 V to 18 V, TA = 25°C, and input capacitance (CIN) = output capacitance (COUT) = 0.1 µF, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
OUTPUT VOLTAGE VOUT 2.499 2.500 2.501 V INITIAL ACCURACY VOERR ±1 mV 0.04 % TEMPERATURE DRIFT TCVOUT −55°C < TA < +125°C 1 5 ppm/°C REGULATION Line ΔVOUT/ΔVIN −55°C < TA < +125°C 10 20 ppm/V Load ΔVOUT/ΔILOAD Load current (ILOAD) = 0 mA to 10 mA, VIN = 4 V, −55°C < TA < +125°C −50 +50 ppm/mA ΔVOUT/ΔILOAD ILOAD = 0 mA to −5 mA, VIN = 4 V, −55°C < TA < +125°C −50 +50 ppm/mA OUTPUT CURRENT CAPACITY ILOAD Sourcing 10 mA Sinking −5 mA QUIESCENT CURRENT IIN No load, −55°C < TA < +125°C 3 3.75 mA VOLTAGE NOISE eN p-p 0.1 Hz to 10 Hz 1.2 µV p-p Density eN 1 kHz 48 nV/√Hz TURN-ON SETTLING TIME tR 10 µs LONG-TERM STABILITY1 ∆VOUT 1000 hours 50 ppm OUTPUT VOLTAGE HYSTERESIS VOUT_HYS 70 ppm RIPPLE REJECTION RATIO RRR Input frequency (fIN) = 1 kHz −80 dB SHORT CIRCUIT TO GND ISC 27 mA SUPPLY VOLTAGE Operating Range VIN 3 18 V Headroom VIN − VOUT 500 mV 1 The long-term stability specification is noncumulative. The drift in the subsequent 1000 hour period is significantly lower than in the first 1000 hour period. Rev. 0 | Page 3 of 8 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
