Datasheet HMC997LC4 (Analog Devices) - 5
DescriptionAnalog Variable Gain Amplifier SMT, 17 - 27 GHz
Pages / Page8 / 5 — HMC997LC4. VARIABLE GAIN AMPLIFIER. 17 - 27 GHz. Absolute Maximum …
File Format / SizePDF / 465 Kb
HMC997LC4. VARIABLE GAIN AMPLIFIER. 17 - 27 GHz. Absolute Maximum Ratings. Bias Voltage. Outline Drawing. Package Information
HMC997LC4 VARIABLE GAIN AMPLIFIER 17 - 27 GHz Absolute Maximum Ratings Bias Voltage Outline Drawing Package Information
HMC997LC4
v02.0514
Drain bias Voltage (Vdd1, 2, 3) +5.5V Vdd1,2,3 (V) idd Total (ma) T Gate bias Voltage (Vgg1, 2) -3 to 0V +5V 170 m Gain Control Voltage (Vctrl) -5 to 0V Vgg1,2 (V) igg Total (ma) rf power input (rfin) +5 dbm 0V to -2V <0.1 ma Channel Temperature 175 °C r - S Continuous pdiss (T = 85 °C) 0.92 W (derate 10.2 mW/°C above 85 °C) [1] ie eleCTrOSTaTiC SenSiTiVe DeViCe Thermal resistance 97.6 °C/W (Channel to ground paddle) ObSerVe HanDlinG preCaUTiOnS lif Storage Temperature -65 to +150 °C p Operating Temperature -40 to +85 °C m eSD Sensitivity (Hbm) Class 0 passed 100V a in a
Outline Drawing
le G b ia r a V nOTeS: 1. paCKaGe bODY maTerial: alUmina. 2. leaD anD GrOUnD paDDle plaTinG: GOlD flaSH OVer niCKel. 3. DimenSiOnS are in inCHeS (millimeTerS). 4. leaD SpaCinG TOleranCe iS nOn-CUmUlaTiVe. 5. paCKaGe Warp SHall nOT eXCeeD 0.05 mm DaTUm – C – 6. all GrOUnD leaDS anD GrOUnD paDDle mUST be SOlDereD TO pCb rf GrOUnD.
Package Information
part number package body material lead finish mSl rating package marking [2] HmC997lC4 alumina, White Gold over nickel mSl3 [1] H997 XXXX [1] max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 pp3li o ca rti a o pp n Susp@h portitti : P te ho .c neom : 1-800-ANALOG-D
