Datasheet HMC694LP4, 694LP4E (Analog Devices) - 5
DescriptionAnalog Variable Gain Amplifier SMT, 6 -17 GHz
Pages / Page8 / 5 — HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 …
File Format / SizePDF / 495 Kb
HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Absolute Maximum Ratings. Bias Voltage
HMC694LP4 / 694LP4E GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Absolute Maximum Ratings Bias Voltage
HMC694LP4 / 694LP4E
v02.1108
Drain bias Voltage (Vdd1, 2, 3) +5.5V Vdd1,2,3 (V) idd Total (ma) gate bias Voltage (Vgg1, 2) -3 to 0V +5.0 170 gain Control Voltage (Vctrl) -3 to 0V Vgg1,2 (V) igg Total (ma) rf power input +5 dbm 0V to -2V <3 µa Channel Temperature 175 °C Continuous pdiss (T = 85 °C) 0.92 W (derate 10.2 mW/°C above 85 °C) [1] eleCTrOsTaTiC sensiTiVe DeViCe Thermal resistance 97.6 °C/W (Channel to ground paddle) ObserVe HanDling preCaUTiOns storage Temperature -65 to +150 °C Operating Temperature -40 to +85 °C 12 T
Outline Drawing
m s - g lO a n a s - r ie nOTes: lif 1. leaDframe maTerial: COpper allOY p 2. DimensiOns are in inCHes [millimeTers] 3. leaD spaCing TOleranCe is nOn-CUmUlaTiVe. m 4. paD bUrr lengTH sHall be 0.15mm maXimUm. paD bUrr HeigHT sHall be 0.05mm maXimUm. 5. paCKage Warp sHall nOT eXCeeD 0.05mm. 6. all grOUnD leaDs anD grOUnD paDDle mUsT be in a sOlDereD TO pCb rf grOUnD. a 7. refer TO HiTTiTe appliCaTiOn nOTe fOr sUggesTeD lanD paTTern.
Package Information
le g part number package body material lead finish msl rating package marking [3] b HmC694lp4 low stress injection molded plastic sn/pb solder msl1 [1] H694 XXXX ia r HmC694lp4e roHs-compliant low stress injection molded plastic 100% matte sn msl1 [2] H694 XXXX a [1] max peak reflow temperature of 235 °C V [2] max peak reflow temperature of 260 °C [3] 4-Digit lot number XXXX Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m
12 - 5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
