Datasheet HMC694LP4, 694LP4E (Analog Devices) - 8
DescriptionAnalog Variable Gain Amplifier SMT, 6 -17 GHz
Pages / Page8 / 8 — HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 …
File Format / SizePDF / 495 Kb
HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Evaluation PCB
HMC694LP4 / 694LP4E GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Evaluation PCB
HMC694LP4 / 694LP4E
v02.1108
12 T m s - g lO a n a s - r ie
List of Materials for Evaluation PCB 122174 [1]
The circuit board used in the application should use lif item Description p rf circuit design techniques. signal lines should J1, J2 pCb mount sma rf Connectors have 50 Ohm impedance while the package ground m J3 - J9 DC pin leads and exposed paddle should be connected C1 - C6 100 pf Capacitor, 0402 pkg. directly to the ground plane similar to that shown. C7 - C12 1000 pf Capacitor, 0603 pkg. in a a sufficient number of via holes should be used to C13 - C18 2.2 µf Capacitor, Case a a connect the top and bottom ground planes. The U1 HmC694lp4(e) Variable gain amplifier evaluation circuit board shown is available from Hit- pCb [2] 122172 evaluation pCb tite upon request. [1] reference this number when ordering complete evaluation pCb le g [2] Circuit board material: arlon 25fr b ia r a V Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
12 - 8
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
