Datasheet HMC694LP4, 694LP4E (Analog Devices) - 3
DescriptionAnalog Variable Gain Amplifier SMT, 6 -17 GHz
Pages / Page8 / 3 — HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 …
File Format / SizePDF / 495 Kb
HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Return Loss @ Voltage Extreme
HMC694LP4 / 694LP4E GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Return Loss @ Voltage Extreme
HMC694LP4 / 694LP4E
v02.1108
GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Return Loss @ Voltage Extreme Output Return Loss @ Voltage Extreme
0 0 -5 -5 ) (dB -10 (dB -10 S S S S LO -15 LO -15 N N R R U U T -2V T -20 -20 -2V E E 0V 0V R R -25 -25 -30 -30 6 8 10 12 14 16 18 6 8 10 12 14 16 18 12 FREQUENCY (GHz) FREQUENCY (GHz) T
Noise Figure vs. Temperature Noise Figure vs. CTRL
m 10 22 6 GHz s 20 17 GHz 8 - ) 18 ) 14 GHz g (dB (dB 16 E 6 E R R U U 14 IG IG lO F F 12 E 4 E a IS IS (6, 8, 10, 12, 14, 17) GHz O 10 O 6 GHz N N n +25C 2 +85C 8 a -40C 6 17 GHz 0 4 s - 6 8 10 12 14 16 18 -1.6 -1.4 -1.2 -1 -0.8 -0.6 -0.4 r FREQUENCY (GHz) CONTROL VOLTAGE (V) ie lif
P1dB vs. Temperature Psat vs. Temperature
p 28 28 m 24 24 20 20 in a Vctrl = -2V Vctrl = -2V 16 16 a (dBm) Vctrl = 0V (dBm) 12 12 P1dB Psat Vctrl = 0V 8 8 le g +25C 4 +85C 4 +25C +85C b -40C -40C 0 0 ia 4 6 8 10 12 14 16 18 4 6 8 10 12 14 16 18 r FREQUENCY (GHz) FREQUENCY (GHz) a V [1] Tested with broadband bias tee on rf ports and C1 = 10,000pf [2] C1, C6 and C8 = 100pf, l1 = 24nf Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m
12 - 3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
