Datasheet HMC694LP4, 694LP4E (Analog Devices) - 4
DescriptionAnalog Variable Gain Amplifier SMT, 6 -17 GHz
Pages / Page8 / 4 — HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 …
File Format / SizePDF / 495 Kb
HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Reverse Isolation vs. Temperature
HMC694LP4 / 694LP4E GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Reverse Isolation vs Temperature
HMC694LP4 / 694LP4E
v02.1108
GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Reverse Isolation vs. Temperature Output IP3 vs. Temperature
-30 34 ) 30 -40 (dB N +25C IO +85C 26 T -50 -40C Vctrl = -2V, Pout = 15dBm LA O 22 (dBm) IS Vctrl = 0V, Pout = 8dBm E -60 S IP3 R 18 E V E R -70 14 +25C +85C -40C -80 10 6 8 10 12 14 16 18 4 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY (GHz) 12
Output IP3 @ 0 dBm Output IP3 @ 5 dBm
T 28 28 m 26 26 16 GHz s 24 24 12 GHz - ) 22 ) 22 g (dBm 20 (dBm 20 7 GHz IP3 IP3 18 18 7 GHz lO 12 GHz 16 16 a 16 GHz 14 14 n a 12 12 -0.8 -0.6 -0.4 -0.2 0 -1.2 -1 -0.8 -0.6 -0.4 -0.2 0 CONTROL VOLTAGE (V) CONTROL VOLTAGE (V) s - r ie
Output IP3 @ 10 dBm
30 lif 7 GHz p 28 m 26 ) 12 GHz 24 (dBm in a 22 IP3 a 20 16 GHz 18 le g 16 b -2 -1.8 -1.6 -1.4 -1.2 -1 -0.8 -0.6 CONTROL VOLTAGE (V) ia r a V Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
12 - 4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
