Datasheet HMC694LP4, 694LP4E (Analog Devices) - 2
DescriptionAnalog Variable Gain Amplifier SMT, 6 -17 GHz
Pages / Page8 / 2 — HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 …
File Format / SizePDF / 495 Kb
HMC694LP4 / 694LP4E. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Control Voltage Range vs. Gain
HMC694LP4 / 694LP4E GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Control Voltage Range vs Gain
HMC694LP4 / 694LP4E
v02.1108
GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Control Voltage Range vs. Gain Gain vs. Control Voltage
25 25 Vctl = -2.0V 10 GHz 20 Vctl = -1.3V 20 Vctl = -1.2V 15 15 ) 6 GHz Vctl = -1.1V (dB (dB 17 GHz 10 10 IN IN A A G Vctl = -1.0V G 5 5 13 GHz 0 0 Vctl = -0.8V Vctl = 0V -5 -5 5 7 9 11 13 15 17 19 -1.6 -1.4 -1.2 -1 -0.8 -0.6 -0.4 FREQUENCY (GHz) CONTROL VOLTAGE (V) 12
Broadband Gain & Return Loss Gain vs. Temperature
T 30 30 m 20 25 s ) 10 20 - (dB S21 ) E S11 S S22 (dB g N 0 15 O IN P A S G E +25C R -10 10 +85C lO -40C a -20 5 n a -30 0 4 6 8 10 12 14 16 18 20 22 24 26 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY (GHz) s - r ie
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
0 0 lif p -5 -5 m ) (dB -10 (dB -10 S S S S LO -15 LO -15 in a N N R R U U a T +25C +25C T -20 -20 E +85C E +85C R -40C R -40C -25 -25 le g -30 -30 b 6 8 10 12 14 16 18 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY (GHz) ia r a V Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
12 - 2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
