HMC900LP5E v04.0811 50 MHz DUAL PROGRAMMABLELOW PASS FILTER with DRIVERTypical ApplicationsFeatures The HMC900lP5e is ideal for various modulation low Noise Figure: 12 dB systems: High linearity: Output IP3 +30 dBm • Baseband filtering before a/D or after D/a converters Pre-programmed and/or Programmable Bandwidth: for point-to-point fixed wireless or base station 3.5 MHz to 50 MHz. (Please see “HMC900lP5e transceivers (gsM/gPRs, WCDMa & TD-sCDMa) Ordering Information”) • Integrated direct conversion receiver (DCR) when Integrated aDC Driver amplifier mated with mixer and Vga exceptional 3 dB Bandwidth accuracy: ±2.5% • software defined radio applications 6th order Butterworth Magnitude & Phase Response • anti-aliasing and reconstruction filters automatic Filter Calibration • Test and measurement equipment external y Control ed Common Mode Output level 3 simplifies Interface Filter Bypass Option: 100 MHz Bandwidth Read/Write serial Port Interface (sPI) g 32 lead 5x5 mm sMT Package 25 mm2 IN s s Functional DiagramGeneral Description e The HMC900lP5e is a 6th order, programmable C bandwidth, ful y calibrated, dual low pass filter. It O features 0 or 10 dB input gain setting and supports R arbitrary bandwidths from 3.5 MHz to 50 MHz, and when calibrated, is accurate to +/-2.5% of the desired bandwidth. It includes a 100 MHz bandwidth l P filter bypass option while retaining gain setting and a common mode control. N Housed in a compact 5x5 mm sMT QFN package, Ig the HMC900lP5e requires minimal exter- s nal components and provides a low cost alternative to more complicated switched discrete filter architectures. D The integrated aDC driver and external y control ed N common mode output level further simplify system a implementations. B Filter calibration for the HMC900lP5e is accomp- e lished with any reference clock rate from 20 to 80 s MHz. One time programmable (OTP) memory offers a unsurpassed flexibility al owing the user “set and forget” parameters like gain and bandwidth setting. Matched filter paths provide excel ent quadrature balance, making the HMC900lP5e ideal for I/Q IF / B communications applications. The 6th order Butterworth transfer function delivers superior stop band rejection while maintaining both a flat passband and minimal group delay variation. Information furnish F e o d br y p A rnialcoe g ,D edvie ce lis vie s rby eli ,e vaen d td o tbo e ap cc la uracte e ao n r d d rel e ia rblse,. p Ho le we a ve s r, en o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other contact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 3 - 1 2 Elizabeth Drive, Chelmsford, MA 01824 Phon rights of third parties that may result from its use. Specifications subject to change without notice. No e: P9h7 o 8 ne-2 : 7 50 81- - 3 3 2 3 9- 4 4 3 70 Fax 0 • O : rd 9 e 7 r o 8 nl - i 2 n 50 e at -33 ww 7 w. 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. analog.com Order On Trademarks and registered trademarks are the property of their respective owners.-line at www.hAit p ti p tlie c .ac ti o o m n Support: Phone: 1-800-ANALOG-D
