Datasheet HMC900LP5E (Analog Devices) - 9
Description50 MHz Dual Baseband Programmable Low Pass Filter
Pages / Page26 / 9 — HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. Table …
HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. Table 5. Pin Descriptions. 3 - 9
HMC900LP5E 50 MHz DUAL PROGRAMMABLE LOW PASS FILTER with DRIVER Table 5 Pin Descriptions 3 - 9
HMC900LP5E
v04.0811
50 MHz DUAL PROGRAMMABLE LOW PASS FILTER with DRIVER Table 5. Pin Descriptions
(Continued) Pin Number Function Description Interface schematic 20 CMI Inphase (I) channel output common mode level Inphase (I) Channel 5V supply. Must be locally decoupled 21, 23 VDDi to gND 22 VDDCal Calibration 5V supply. Must be locally decoupled to gND 3 Inphase (I) channel positive and negative differential 26, 27 IIP, IIN inputs respectively g 28 VDDBg Bias 5V supply. Must be locally decoupled to gND. IN s s e 29 VBg 1.2V Bandgap output (testing only) C O R l P a Quadrature (Q) channel negative and positive differential 30, 31 IQN, IQP N inputs respectively Ig s D N a B e s a IF / B Information furnish F e o d r b y pArnic alo e g , D d evi ecleis vie s rby eli, ea ve n d d to tbo e apl cc a ur c at e e ao n r d d releiars ble ,. p Ho le we a vesr, en c o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 2 Elizabeth Drive, Chelmsford, MA 01824 Phon rights of third parties that may result from its use. Specifications subject to change without notice. No e: 9 Ph 7 o 8 n - e 2 : 750 81- - 3 3 2 3 9- 4 4 3 7 0 Fax 0 • O : rd 9 e 7 r o8 nl-i2 n 50 e at -33 ww 7 w. 3
3 - 9
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptiptliec.actio o m n Support: Phone: 1-800-ANALOG-D
