Datasheet HMC681ALP5E (Analog Devices) - 7
Description0.5 dB LSB GaAs MMIC 6-BIT Digital Variable Gain Amplifier with Serial Control, DC - 1 GHz
Pages / Page11 / 7 — HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER …
File Format / SizePDF / 825 Kb
HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz
HMC681ALP5E 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz
HMC681ALP5E
v00.0113
0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz Absolute Maximum Ratings Bias Voltage
RF Input Power [1] (At Max Gain Vdd (V) Idd (Typ.) (mA) T -10.5 dBm (T = +85 °C) Setting) +5 2.5 M Digital Inputs (Reset, Shift Clock, -0.5 to Vdd +0.5V Vs (V) Is (mA) Is (mA) 1 2 Latch Enable & Serial Input) +5 91 91 Bias Voltage (Vdd) 5.5V
Control Voltage Table
L - S Collector Bias Voltage (Vcc) 5.5V Channel/Junction Temperature 150 °C State Vdd = +3V Vdd = +5V ITA Continuous Pdiss (T = 85 °C) 1.18 W (derate 18.2 mW/°C above 85 °C) [2] Low 0 to 0.5V @ <1 µA 0 to 0.8V @ <1 µA IG Thermal Resistance [3] 55 °C/W High 2 to 3V @ <1 µA 2 to 5V @ <1 µA Storage Temperature -65 to +150 °C Operating Temperature -40 to +85 °C S - D [1] The Max RF Input Power Rating will increase by 0.5 dB for every 0.5 dB reduction in gain to a maximum RF Input Power of ELECTROSTATIC SENSITIVE DEVICE R 10 dBm. OBSERVE HANDLING PRECAUTIONS IE [2] This value is the total power dissipation in the amplifier. LIF [3] This is the thermal resistance for the amplifier. P M IN A A LE G B IA R A V I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
